SOURCE: McCulloch 32cc blower, what is the fuel mixture, gas/oil
Do a 40:1 ratio to start, if it smokes cut it back alittle but 40:1 should be ok. Better to be alittle high on mix than not enough.
SOURCE: What is the gas and oil mixture ratio?
Hi, McCulloch chain saws have different mixtures depending on whether you use their brand or generic and is also dependent on the model. The three mixes are 32:1, 40:1 or 50:1. If you are unsure, use the 40:1 and watch the smoke, too much smoke use less mix, but don't run with too little. If you see any coming from the exhaust it is too much and can't burn it all. Good Luck, hope this Fixsya!
SOURCE: Gas Oil Mixture
Fuel Mix: Add 6 oz. McCulloch custom lubricant or 1 PT. S.A.E. 40 (16:1) to 2 U.S. Gal. Regular Gas
SOURCE: what is the oil to gas mixture ratio on 1995 Toro
The proper mix is 50:1. The link to the manual is
http://ourfamilys.deandrea.net/BobKitty/User%20Guides/tosnowss.pdf
The fuel mixtures can be found on page 11. Hope this helps.
SOURCE: , No.455 Rancher, 20" Gas - Powered Chainsaw: What is the oil mixture ratio for the Rancher 455...
50: 1; You can download an OM here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years and is what Husky suggests for your saw..
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
• 1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
• 4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
• 1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
• 4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
