Question about Refrigerators
Rs261mdwp not cooling and freezer not working. was not used for 6 years
    Top Expert:
  • Refrigerators Master
  • 5,795 Answers
Compressor / sealed system problem, or maybe a wiring problem. Hard to say.
Posted on Jan 10, 2019
3 Suggested Answers
davidpsr
  • 222 Answers
SOURCE: refrig not cooling
Either the fan that blows cold air from the freezer compartment to the fresh food compartment is burned out or the door/flap that seperates the compartments is stuck or the linkage connecting it to the fresh food temperature dial is stuck or broken.
The evaporator coils are in the freezer compartment and air is blown from the freezer compartment to cool the fresh food compartment. For some reason, air is not moving to fresh food compartment.
If the fan is running, it could be something as simple as Ice blocking to door between the freezer and fresh food compartment. I know modern refrigerators are self-defrosting, but that's only the evaporator coils, which are defrosted by a timer and a heater.
Ice can form on passageways inside the refrigerator, like the exit of the ice maker and in this case, on the door and 'tunnel' between the freezer and fresh food compartment. It's free, and doesn't take a lot of time, so try completely defrosting the unit before doing anything else.
BE SURE to keep the doors open, as odors can form as particles of food are allowed to defrost that may have been frozen in an ice pack for months or even years. Clean the interior of the refrigerator while you have everything out and reset the controls to normal settings.
If this doesn't help, there may be a mechanical problem with the air transfer control flap/door that will need to be fixed.
Hope this helps.
Posted on Jun 11, 2009
  • 1531 Answers
SOURCE: freezer works but bottom not cooling
there be a problem with your evaportor fan in the freezer compartment not running.but if it is running you may have a defrost issue.and ice is building up on the evaporator causing the air flow to be blocked.i hope this has help you out some.please let me know how things go for you.
Posted on Jan 22, 2010
The light on the freezer side keeps blinking but refrigerator side not working flashing
possible the freezer needs a recharge of freon . only a repairman can assist with that .
Sep 06, 2015 | Samsung RS261MDWP Side By Side...
How do I adjust the temperature to make the refrigerator cold
usually there is a control knob inside the fridge just turn it to colder and see what happens
Feb 03, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
It dosn't cool
try unplugging and back in . or turn breaker off then on
Aug 29, 2014 | Samsung RS261MDWP - 26 cu. ft. Side by...
Fan malfunction in the freezer samsung rs261mdwp
If your questioning is how to replace it its no easy task. It involves removing everything from the freezer and all the shelving. The back inner panel of the freezer compartment and then removing and replacing the fan. Followed by reassembling everything.
Jul 25, 2014 | Samsung 26 cu. ft. Side by Side...
The freezer door wasn't closed properly overnight 2 nights ago and it still didn't cool properly after the whole day yesterday and today. There was a noise which I didn't recognize but now in retrospect...
Is RS261MDWP the correct model number? If you left the freezer door open there is an excess amount of frost covering the evaporators because moisture was drawn inside and has frozen on the evaporator and is too much for a normal defrost to get all of the ice off and drain into the pan below the refrigerator. It may have also frozen over the condensate drain and not allowing the water to drain. You may need to clean the drain hole and defrost the refrigerator manually and insure the evaporators are clear of backed up water. If you don't there is a chance the refrigerator will continue like this until you do. Let me know what the status is so I can help.....Sea Breeze
Does your model have two evaporators?
Aug 05, 2013 | Samsung / RS261MDWP
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Frig cools works great all day then trips the gfci
Hi Sturkle;
Does this happen say- every 6-8hrs? If so you may find the defrost element has a short, or defrost timer is faulty. Defrost element is located in the freezer compartment, Time located an back of fridge.. Use a qualified person when playing with electrics...Cheers
Mar 29, 2010 | Whirlpool ET8GHMXLQ / ET8GHMXLT Top...
Freezer works but bottom not cooling
Jan 22, 2010 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
