Question about IBM Wheelwriter 30 Typewriter
Delay print How do I get the delay print function to turn off? As it is, I type a line and it only types out after I hit return. I would like to be able to have the typewriter actually type as I type in the letter. Please help! Thanks.
  • KathyG1 Nov 27, 2007
    I have a wheelwriter 30 with the same problem - how is it corrected?
    Kathy
    kgroner@lcul.org
I found the answer to this situation: To turn off delay print function, Push the print mode button on the upper right hand control keyboard.
Thanks for the help!
Kathy
Posted on Nov 27, 2007
  • 481 Answers
You may have the machine in right margin flush mode try holding the code key down and press the letter "o" ( r flsh)
SOURCE:
I've hit a wrong key and now it won't print what I am typing it just moves along the line
Just hit the mode key until TYPE, on the display, is highlighted. There are 3 modes, TYPE (where the machine functions like a normal typewriter), L/L (Where what you are typing shows up in the display and then prints when you hit the "RETURN" button. You can make corrections, in this mode, before you print the line, which saves using your correction tape.) and STORE (which is used to store memory information, such as format and phrases.)
Sep 28, 2015 | Brother EM-430 Typewriter
Why is my typewriter going backward
Not sure what you mean and what model it is, sometimes in the electronics if the CENTER function is activated by hitting a key the typewriter will type backwards, then when you hit the carriage return it will print and the line will be in the center of the margins, do not know if this helps but could be answer.
Nov 09, 2014 | Office Equipment & Supplies
I have a a Lexmark Wheelwriter 3500 and it has the delayed printing function, well this does not seem to be working correctly it is typing before it should. what can i do to correct this problem?
If it types as you press the kets delay print is turned off, press the print mode key on the r
R. side until Dl prt is on the display. If it just starts typing at a the same position every time you probably have the R. margin set there and auto return on (CODE R).
DickyO
Jul 27, 2011 | Lexmark Wheelwriter 3500 Typewriter
When typing the letter don't appear
If they don't print until you hit the return key you are in the delay print mode, use the print mode key on the R. side to get out of it. If it isn't printing at all the plastic print solenoid cap is broken. We sell them with shipping and instructions for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Jun 13, 2011 | Lexmark Wheelwriter 5000 Typewriter
With a startype 3, do you have to use the delay function ( where you type then return to get type to print)?
The mastertype 3 is the same machine as the nakajima ae710. Go to NADIST.COM, click on current models you will find a manual there, it will tell you how to get out of the delay print mode.
DickyO
Feb 17, 2011 | Olympia Mastertype 3 Typewriter
IBM Wheelwriter doesn't type until I hit return button.
On the R. side of the keyboard is a key that says print mode press this key and the dl print on the displaywill go out.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
How do i turn off the delayed type on a ibm wheelwriter6
at the very top right of your keyboard there is a "print mode" key
press this key until the note in the left lower coner of the display says "char print"
however in delay print you can correct mistakes before you print - saves on correction tape
Nov 17, 2008 | IBM Wheelwriter 30 Typewriter
Print as I type not after Return
On the R. side of the keyboard is a print mode key press it and the delay print on the display will go out and you should be set.
DickyO
Aug 21, 2008 | Lexmark Wheelwriter 3500 Typewriter
Delayed typing
On the far rt. side of the keyboaed is the print mode key, press it and the DP will go out on the display.
Hope this helps
DicktO
Dec 27, 2007 | IBM 3500 Typewriter
IBM Wheelwriter 30 Typewriter Logo
293 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
