Try the above
Hi There,
I'm attaching a link on how to do a hard reset just in case you missed any step. If the phone is still not going into recovery mode for you, you may need to do it through sharp pc suite software. Install the software and drivers on your pc and try to recover your phone through the software. Again the link is below. Hope this helps you.
https://www.hardreset.info/devices/sharp/sharp-sh-06d-aquos/hardreset/first-method
https://drive.google.com/file/d/0B3dB8gqXWE72azJ1d2s2VTQ0cTg/view?usp=sharing
https://docs.google.com/uc?
id=0B3dB8gqXWE72a2pEU0RPYkVTLTQ&export=download
SOURCE: Cannot Get Jabra BT150 into Pairing Mode
I had problem with my bluetooth not getting into pairing mode,and Now it working good.
Thank you for your best solution.
SOURCE: LG Chocolate: Camera Button reboots phone
The problem was solved by replacing the flex cable that connects the two halves together. My phones screen is back, all the buttons work, and the camera button no longer reboots the phone (also going to camera through mypix doesn't cause reboot either). The cable was very easy to replace and took me 10 minutes at most only using a screw driver and the info in the link I provided ealier.
SOURCE: How do I do a
Hard Reset Procedure
Good luck. If this helps you plz rate it fixa. Thank you kindly.
SOURCE: Phone won't open, red light flashing.
bring your phone to a local repair shop and have the ROM erased then have the phone software reinstalled.
Select Factory reset with Volume Down button and press Power to reset. All data will be lost!
