Question about LG Microwave Ovens
LG microwave displaying diamond with line down the centre and it is flashing. The microwave will set clock and timer but nothing else.
SOURCE:
SOURCE: the microwave starts, then stops 2 seconds later
I tried a solution posted on another posting http://www.fixya.com/support/t242480-stops_cooking by placing the conductive plastic behind the control panel and it worked.
Posted on Jan 06, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: display not workign
Sadly, the display tube is not available separately, so the only way to fix this is to replace the board, at a whopping $181.48!
One trick that helps is to remove the control panel assembly, take the circuit board out of the frame and very carefully wipe the front of the glass and the rear surface of the control panel frame's display window.
Use a soft cloth with alcohol-based (non-ammonia) window cleaner.
That will brighten it up quite a bit.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Be sure to unplug the oven before you do any disassembly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: How to set the timer? No manual
One of the manuals on this page may help.
If not, select the customer care link to the left to order one.
Posted on Jan 29, 2009
  • 132 Answers
SOURCE: Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
Posted on Mar 30, 2009
SOURCE: Microwave Oven EM-804T
When I opened up the microwave cover, noticed that the door latch mechanism was worn and not holding up the interlock switch. A thick piece of tape on the worn piece of plastic and microwave was back to working (I had symptom of the timer counting down without the microwave turning on)
Posted on Nov 01, 2010
How to reset the clock on a Panasonic NN-SA651S microwave.
hi carol.
try this,if this does not work go to the link.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set. You are now ready to use your new Panasonic Microwave Oven. When you first turn on yourmicrowave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . .
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How to reset the clock on Panasonic NN SA651S microwave Google Search
Nov 07, 2017 | Panasonic Microwave Ovens
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
How can I to set clock on Sanyo Microwave EM-C678
1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
Sep 03, 2014 | Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Microwave has power, but nothing works.
    The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
    Mar 18, 2012 | Panasonic Microwave Ovens
    Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
    According to the manual this is how to set clock.
    To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
    Enter time of day. The time appears in the window; the colon continues to flash.
    If you need the manual it is on link below.
    http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
    Good Luck
    Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
    Microwave oven (nn-sd997s) stuck in DEMO mode
    Pressing "timer/clock" button 4 times turns on and off demo mode.
    Apr 26, 2008 | Microwave Ovens
    Keypad Problem?
    look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
    May 25, 2007 | Emerson MW8168B Microwave Oven
    Microwave Ovens Logo
    111 people viewed this question
    Top LG Microwave Ovens Experts
    William Miller
    William Miller
    Steve Allison
    Steve Allison
    Jerry Greenberg
    Jerry Greenberg
    Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
