TCL LE32HDF3300 32 Inch LED LCD HDTV Logo
A
Anonymous Posted on Jan 10, 2019
I have a TCL model#L40P60UF and as soon as i plunge in to a power point a red light just turns on for a few seconds than nothing Can u help me out guys
Please help! I have a TCL 65S421, when you power it on it flashes the TCL logo, then goes back to black for a few seconds, then flashes on and off again
Hi Riley, you can change every board in the TV and it's still not going to work, you have bad LED lamps, the strips need to be replaced to fix he set. The tolerances for the inverter current are really close on this model set, it's going into over current shutdown.
Hi Ive got TCL tv model L40P60UF and if I press any button on remote control, it continues "pressing" by itself. I tried change batteries in remote control - didnt work. Plz help! Tnx
It might seem silly, but often this is due to a physically sticking button, often dirt in the remote. You can try using a spray switch cleaner. If that fails try buying a replacement remote. They are usually cheap and available online
TCL TV Model L40P60UF; no picture and sound when switched on but stanby led is on. When power on is pressed from the remote control, the red led disappear. What could be the problem
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
T.V TCL L40P60UF How To take The Language Back To English
I've been successful helping other friends with this by going online and finding a language translator that'll guide you through a Factory Reset (or System Reset) where you should be able to choose your choice of language settings. Be patient with this one.
Jun 28, 2014 • GPS
1helpful
The ps3 used to work on my TCL LCD TV but it isnt any longer i think my son changed some settings on the ps3 console
Please try the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
16helpful
4answers
TCL tv
i have tcl satellite tv...the porblem is when i switched on , 5 or more minutes after, the tv unit shut off itself. Sometimes the tv scan its channels first before having picture then shut off after few minutes..varying time when shutting off.....And when using for video movies everything alright....please tell me what to do??...any solutions??..advance thanx to those who could help...
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
john h
ADMIN Andrew
ADMIN Andrew
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
