Gateway nv53
but you skipped all numbers to the right of 53,
nv53-1234(????)
given the lack of what PC this is fully
we dont know what CPU you have nor GPU video chip
w10 i bet ill not load on this processor
even the best one m660 will not load.
the oldest one supported AMD is A-serices
like a8
are you erasing the hdd and freshloading the OS?
now data;
why not learn the name of one video file first.
then using windows start + search find that file.
or backup you users folder.
c:/user/"youraccountname/
this is your logged in account name,.
where it is in there is anyones guess.
the CAMERA APP you used is unstated,nor VERSION.
NV53 ACER ASPIRE LAPTOP
the true name
and has built in camera,.
there is no camara app for w10 on this PC by gateway,so...
the new PC had 2 options day 1.
the chicony and Suyin
and 2 totally different apps. for both.
w7 only
and if both save fails same place id be surprised, ?
then turn off hidden files, in explorer view settings
the use start search and it will find that file and tell you where it is.
and bingo all the rest.
w10, no!
THE nv53 IS NOT full model number
it is series only that number
here is what some nv53 used
so the question is does w10 run no these
w10-64 I bet NOT.
W10 32 even lowly 32, will not like this.
AMD Turion™ II Ultra dual-core mobile processor M660 (2.70 GHz, 2 MB L2 cache, DDR2 800 MHz, 35 W)
AMD Turion™ II Ultra dual-core mobile processor M640 (2.60 GHz, 2 MB L2 cache, DDR2 800 MHz, 35 W)
AMD Turion™ II Ultra dual-core mobile processor M620 (2.50 GHz, 2 MB L2 cache, DDR2 800 MHz, 35 W)
AMD Turion™ II Ultra dual-core mobile processor M600 (2.40 GHz, 2 MB L2 cache, DDR2 800 MHz, 35 W)
AMD Turion™ II dual-core mobile processor M540 (2.40 GHz, 1 MB L2 cache, DDR2 800 MHz, 35 W)
AMD Turion™ II dual-core mobile processor M520 (2.30 GHz, 1 MB L2 cache, DDR2 800 MHz, 35 W)
AMD Turion™ II dual-core mobile processor M500 (2.20 GHz, 1 MB L2 cache, DDR2 800 MHz, 35 W)
AMD Athlon™ II X2 dual-core processor M340 (2.20 GHz, 1 MB L2 cache, DDR2 667 MHz, 35 W)
AMD Athlon™ II X2 dual-core processor M320 (2.10 GHz, 1 MB L2 cache, DDR2 667 MHz, 35 W)
AMD Athlon™ II X2 dual-core processor M300 (2.00 GHz, 1 MB L2 cache, 2DDR2 667 MHz, 35 W)
AMD Sempron™ processor M120 (2.10 GHz, 512 KB L2 cache, DDR2 667 MHz, 25 W)
AMD Sempron™ processor M100 (2.00 GHz, 512 KB L2 cache, DDR2 667 MHz, 25 W)
which one you have is anyones guess.
run hwinfo32.exe portable and see CPU name
and GPU name,
Graphics Chipset ATI Mobility Radeon HD 4570
some use this abovve GPU. again hwinfo32 tells you.
what I do is
remove the HDD, and put in any spare HDD
erased, and load w10-32 (64 will not work)
and see how well it works
a used HDD is like what $15?
this PC worth $20 , too old to be useful
windows 10 can reject the PC for
non supported BIOS
processor (for sure old intel versions)
GPU card, not supported
Lan chip or wifi chip has no driver (too old)
no sound chip driver
or lack of north or south bridge chip support. for example Nforce chips, relics
or very first ICH1,2,3 chips by intel, glue
so nobody knows , all that. (no model stated)
you didnt post full model numbers
but I do the spare HDD trick, tell w10
will activate later, 29 days later, LOL
W10 wants PCs 2010 or newer
with at least a intel, core(tm) i3 in it.
64bit needs, core gen 5 up.
amd needs below list
amd rules, limits off ms.com, site.
AMD processors
so NO is the answer, 7th gen is limit.!!!
Up through the following AMD 7th Generation Processors
(A-Series Ax-9xxx & E-Series Ex-9xxx & FX-9xxx), AMD Athlon 2xx, and AMD Ryzen 3/5/7 2xxx
AT LEST THIS
https://www.amd.com/en/products/a-series...
SO NO.
best is to try on spare drive
or go to ms.com forum
ask of your unstated PC is support.
i think not even close
SOURCE: T3 sync with PC- Windows XP
Need to reload software in pc. Dropping stuff. If you found this helpful, please post as so. If you need to knwo how, live chat
SOURCE: How do I get access to Internet from Gateway NV53
Make sure the router is properly connected, connect the laptop to the router, and browse away.
SOURCE: I purchased a gateway nv53 Laptop> It has
i had this same problem with my lexmark,no drivers available for win7.found one to get it to print,but nothing for the scanner feature...try updating your drivers and see if it helps.
SOURCE: Gateway NV53 web camera does
hello screwdra
it sounds like you dont have the correcrt video driver for your webcam.
hope this helps
please rate
SOURCE: installed ubuntu on my gateway NV53 and now my built in webcam cant be found
Download and install Cheese using the ff. steps: To record video or take a snapshot, click either on photo or video and select Take a Photo or Start recording. If Cheese displays a garbled picture or one with poor colour/brightness/contrast, go to the Ubuntu wiki Webcam Troubleshootingpage for steps to resolve this.
