Question about Sanyo Heating & Cooling
Sanyo C122C25 wall mount. Air and heat...just suddenly quit heating...power is on but blows cold air
  • 26 Answers
If it is new split air conditioner with a four way valve and it stops giving heat. Check if there is any power going to the coil of the four-way valve. Check also the continuity of the coil. If there is power and the continuity, replace the four-way valve. If you don't get power going to the coil, check the wiring. If wiring is good, replace the electronic control board.
Posted on Jan 11, 2019
SOURCE:
  • 24 Answers
SOURCE: heat works on driver side, passenger side blows cold air.
Did you check your coolant level or was it low and you added to it at some point? If so the system my need to be bleed or worst case the thermostat is going bad.
Posted on Jan 03, 2009
diths_kri
  • 67 Answers
SOURCE: My Heater blows cold air
IGNITE PROBLEM
Posted on Jan 07, 2009
SOURCE: DRYER BLOWING COLD AIR-NOT HEATING UP
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
I hope this helps....
Posted on Jan 21, 2009
  • 30 Answers
SOURCE: panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Posted on Jul 18, 2009
  • 85 Answers
SOURCE: front heat works, but rear blows cold air only
With your front heat working the most likely cause for the rear heat not to work is that there is an obstruction in the line that is preventing the warm coolant to get to the rear heater core or the rear heater core itself is plugged and not circulating. Another possible cause could be low coolant level where the system has enough coolant to provide the front system with enought warm coolant but not the rear system. Hope this helps
Posted on Dec 30, 2009
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
Why is hot air blowing out of air conditioner
If it is a wall mounted one like the one in the picture and it is fairly new, and possibly a Fujitsu or LG, it may be by design. Modern AC can run backwards to become a heat pump and takes the cold air from outside, extracts warmth and blows it inside for the winter months. The remote has different symbols for heat or cool.
If not new, and only blows cold it needs refrigerant gas, or at worst a new compressor..
Oct 30, 2015 | Heating & Cooling
HOW DO I CHECK AND CORRECT THE FREON LEVEL FOR MY SANYO KS1271 A/C; WHICH IS NOT BLOWING COLD AIR?
Hire a tech it will be cheaper and safer. You may have a capacitor that is bad and not starting the compressor.
Aug 22, 2014 | Sanyo KS1271 11,900 BTU Ductless...
I have a whirlpool wall heat/ac unit, model ACE184XL0. All of a sudden, the heat quit working. Fan still blows, and AC still seems to work, although I can't tell if it's just pulling in cold outside air...
Dear it is a thermostat system. You can simply check it by setting temp at 30 then check either warm air is coming or cool air. at this time warm air should come. If warm air is not coming means there is a fault is realy in your pcb. It can be simply remove no need to worry.
Oct 14, 2013 | Whirlpool ACE244XS Air Conditioner
The heatpump blows out air ok but no heat?
You are probably going to have to call a Hi Vac repair as your freon is probably too low to operate your Heat Pump properly. The only difference between the Air condition side and the heat side is a reversing valve that takes the heat produced by the Air Conditioning (cold) side and sends it into your house and exhaust the cold air out side. If the pump cannot produce heat from the expansion and compression of the freon, then no heat. You may also want to check that the pump is running as it is protected by two large BUSS fuses on the AC power to the heat pump and if any one or both of those fuses are blown, then no power to the Heat Pump. There should be an 8 inch square box mounted on a wall next to the heat pump that supplies 220V to the pump.
May 17, 2011 | Heating & Cooling
Blows warm air but after a few mins turns to cold air...
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 02, 2011 | Kenmore 75124 Wall/Window Air Conditioner
A/c works heating blows cold air
Is this an electric unit? I guess it is. It appears tha the heating elements are not activating. Check to see if the contactor pulled in on a call for cooling>
Oct 20, 2009 | Carrier YC273D Air Conditioner Window/Wall
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Heating & Cooling Logo
Top Sanyo Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Dennis Boxerman
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
