Vehicle Parts & Accessories Logo
Jordan Edwards Posted on Jan 10, 2019
Why does my remote car alarm LED light stays on?
DALE BECKETT
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Mar 13, 2019
DALE BECKETT
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
2743
Points
29
That's usually an indicator light that the system is active...It can also say stay away from the novice thieves but if a pro wants your car you will be making an insurance claim. Pro's will get the car if they want it...
1 Related Answer
airjoc
Rob Sinbad
  • 709 Answers
  • Posted on Aug 26, 2009
SOURCE: newly installed car alarm, LED in solid light n horn/siren blares
if you follow instruction properly than the alarm should work properly, Go over your wiring again 2-3 times make sure it make sense to you with the instructions. If it make sense than take the unit back and get another, can be faulty alarm.
Why did the red flashing alarm light stop flashing? Alarm and remote working fine
Most likely the 12 volt led light burned out.. all bulbs LED too don't last.. Find the 2 wires usually Black and red and check for 12 volts with the alarm set and if you have 12 volts,. you need to go to radio shack and see if they still have 1. 2 volt led bulbs.. Good luck.
1helpful
Is 448V remote compatible with Python Car Alarm?
if its lit solid that usually means a problem with the system... so the alarm portion is most likely not active... or it might simply be in valet mode... without knowing the model of your car that's the best I can offer...
If you need further help, reach me via phone at https://www.6ya.com/expert/jonathan_4cd718ed254374ee
1helpful
Viper 5701 led light does not flash when armed, stays lit when alarm is disarmed
If the LED is on solid then the alarm is in valet. To exit valet, press "F" twice then press unlock on the remote. The LED should turn off.
OR,
enter the vehicle, turn the ignition on then off, press and release the valet/programming button on the antenna. LED should turn off
2helpful
Autopage xt74 alarm in silent mode
The only reason that your alarm would not chirp when locking and unlocking the doors is that the system is in valet. A visual notification that the alarm is in valet mode is the LED light is on solid. If the LED is on solid and you wish to make the alarm active again, turn the ignition on then, press and hold the valet/programming switch for two seconds. The LED light will turn off.
If the LED light is not on solid then, the issue may be with siren itself.
I have a viper remote start that came with the used i car i bought, the remote start worked great for the first few months of winter, now when i start it up, it runs for 2 seconds then dies, takes up to 6...
Your alarm may have lost the tach signal, that was learned to it, when it was originally installed. That would cause the remote start to try starting the vehicle over and over again, until it finally stays running, because it can't read the engine speed to know it's running.
If you can find the valet push button switch in your vehicle, try this; Start your car with the key and immediately after it starts, press and hold that valet push button switch until the alarm led on the dash stays lit up or the park lights flash. Then, release the valet switch, shut the car off and try remote starting it. That is the procedure to re-learn the tach signal. Hope it works for you.
4helpful
My led light for my alarm stays on and the alarm dont work anymore but the button still locks?unlocks/and starts
Your system is in valet. To take the system out of valet with remote: open any door, press lock, unlock, lock. Now check the LED; it should be off. Close the door and arm the system to check.
OR
Turn the key on then off. Within ten seconds press and release the valet switch. The LED should be off now. Close the door and arm the system. The alarm should chirp to confirm that it is armed.
4helpful
I have had my Viper system for some years now with never a problem, that is until yesterday. Now when I arm or disarm my system the horn does not chirp and the small red dash light stays solid red instead...
Your alarm is is in valet. to take the alarm out of valet with the remote: open any door. Press lock, unlock, lock. The LED should be off now. Close the door and lock the doors with remote. The alarm should chirp to confirm that it is armed.
OR
Turn the key on then off. Within ten seconds press and release the valet switch. The LED should be off now. Close the door and lock the vehicle with the remote. The alarm should chirp to confirm that it is armed.
3helpful
Astra remote car starter problem
your remote starter is in valet mode, the door lock will still work but no remote start, try pressing the trunk button 3 times, if that doesn't work turn the ignition switch on and off 5 times
1helpful
Led light stays on
if you are finished with the install, then it's in valet mode. if you are still working on the alarm it's on because the alarm needs a ground.
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
