The induction cooktop will flash "F" when cookware has been removed from the surface; cookware is not present when the unit is turned on; or cookware is not centered on the element.
Position the cookware properly over the center of the cooking surface if the error code "F" flashes. Use only induction cookware and use a bigger pan, as the error code "F" indicates that the pan is too small for the cooking element.
SOURCE: Keeps beeping
My thermador keeps beeping and F1 stays on...what's happening and how do I get it to STOP!
SOURCE: Error code GE induction cooktop
Display flashing “E” alone (no other letter)
A hardware error has occurred.• Call for service.
SOURCE: GE Monogram gas cooktop electric ignitor will not
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
SOURCE: My GE Monogram 5-burner gas cooktop has a constant
My burners used to have the same problem: buzz sound and ignitor clicking. I think you hhave better ask a tech come in to check on it and to fix the problem. I ignored it and then finally it stop but the whole range has to spend big money to replace part. At the end we decided to replaced the whole burners. It won't cost much for the Sears Tech come into check or work on it.
Sandy
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
