I have samsung dryer . it is no turning'
Maybe a broken belt. Maybe a bad door switch. Maybe a bad motor. Maybe improper voltage. Maybe thermal fuse.
Press actuator and start simultaneously, if the drum doesnt spin then it's a belt replacement issue
Testimonial: "Changel belt, idler pulley and 4 rollers. Still drum don't turn and makes humming noise. Little push to drum and everything works fine until next time. Issue is related to first push from motor."
I changed the belt ,idler pulley and 4 rollers. But still problem is same. Once I give small manual push machine runs fine.
