Possibly a clogged piece of ice from water leakage preventing the dispensing of ice. If you haven't tried taking the ice bucket out and rinsing it under hot water to get all the frozen ice out, you should.
Lowering the water pressure to the fridge by turning the knob on the connection at the wall should help prevent the excess water and clogging going forward. There is a very small change between almost off and just on, where the water will still dispense from the front of the fridge but you can tell that the pressure is less, that should give the desired results. It may take some trial and error by testing the water flow from the door while adjusting the valve at the wall.
The water pressure adjustment may help with the flooding problem under the meat/cheese drawer as well, but most likely you have a clogged drain too because it's a very common issue with these fridges. There should be a panel on the bottom back of the fridge with 3 or 4 Phillips head screws that opens access to the drain tubes which are just about in the horizontal center. The drain tubes are little white plastic tubes with flexible bulges (they look like really oversized whitish/clear bendy straws). They are about 5 inches long each and you will probably see a bunch of gunk at the bottom where they enter the plastic evaporation tray. There is a rubber grommet with a flap on the end of them that needs to be cleaned out, and there may even be some ice formed in the tube that needs to be cleaned out. This will take a bit of time and patience while crouching or on your knees, so be ready for that and have towels ready for excess water. I found a turkey baster and a glass of warm water to be very helpful as well.
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
SOURCE: Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
SOURCE: my ge fridge model TBX18k lg has water build
Remove the food from the freezer and then remove the rear freezer wall . Should be 2-4 screws and maybe a clip on each side on the top vent . Once the panel is removed , useing a hairdryer , defrost the tray below the coils until you can see the drain hole . Defrost the drain hole until water begins to flow into the hole . Use a small hose inserted into the hole and blow out any debris which has accumulated . You can also use hot water to help defrost the drain hole . Once completed , reinstaal the panel and of course , food .
SOURCE: water problems
Hi. the first action is to check the water filter(If Equipped). Once a water filter reaches its filtering limit, it will stop the free flow of water immediately. This will require you to replace the filter asap, if needed. Once the filter is replaced, the water will flow freely once more. I would also advise to check the integrity of the lines. If the lines are frozen, this will cause a no-flow situation , as well. check to make sure that the lines are not frozen.
Ok, if the lines and filter are not the issue, kindly,proceed to the inspecting of the water inlet valve assembly.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink, or behind the unit). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.../
