SOURCE: freezer of refigerator (coils keeps freezing over)
I had the same problem, i took mine outside and spayed degreeser on the coils and power washed it off. the coils get built up with dust. make sure you dont have it pluged in when power washing it. lol. good luck
SOURCE: water tube on ice maker freezes up thaw /froze up
You need to replace the water inlet valve , due to seeping when closed . The water valve is the piece on the refrig which the wall water line connects to .
SOURCE: Refrigerator water condensation drain line freezing
GO TO THE FREEZER PORTION OF THE FRIG.YOU NEED TO TAKE THE ICEMAKER OUT AND REMOVE THE BACK PANEL WHERE THE EVAPORATER FAN IS .RIGHT UNDER THE COIL YOU WILL SEE A DRAIN ,WHEN YOUR FREEZER GOES ON DEFROST THE WATER GOES DOWN THE DRAIN AND INTO A PAN THAT SITS ON TOP OF THE COMPRESSOR.THE HEAT FROM THE COMPRESSOR EVAPORATES THE WATER.THE DRAIN IN THE FREEZER IS PROBABLY CLOGGED OR FROZEN OVER WITH ICE AND THATS WHY THE WATER IS GOING ELSEWARE.REMOVE ALL THE ICE FROM AROUND THE DRAIN.IF THERES A ROD THAT GOES DOWN THE DRAIN FROM THE DEFROST ELEMENT THATS SUPPOSED TO KEEP THE DRAIN FROM ICING UP ,IN ANY CASE THE DRAIN IS CLOGGED OR ICED UP.UNCLOG THE GRAIN AND YOU WILL BE GOOD TO GO.
SOURCE: My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp.
The problem could be the electronic control if
you have one or the mechanical linkages.
SOURCE: Freezer drain line keeps freezing over
Good day,
Whirpool machines have a very short defrost cycle, as compaired to many brands. This definitely contributes to the problem.
1. Make sure the drain fittings and drain hose to the drain pan are completely open. Not just open, but blown free of any debrise.
2. My experience with many whirlpool products, is ice built up under and back of the drain pan in the freezer compartment. It cannot be seen.
To solve this problem long term, means unplugging the machine, defrosting, and drying it out completely.
24 hours and idealy with a floor fan blowing into the compartment.
3. As well, you wil notice a small round disk clipped to the top of the evaporator. This is the defrost thermostat, and controls the temperature during defrost.
I change and bump this tstat up 5 degrees.
For example, if it's a 50 degree tstat, I replace it with a 55 degree. Or if it's 55 degrees I use a 60 degree model.
You will not be able to buy this as a Whirlpool item, but you can with a little effort, use a GE kit.
The part number for GE replacement kits are for example "WR50X55", the last 2 numbers are the temperature of that tstat, and run in 5 degree increments from 45 degrees to 60 degrees.
A sharp appliance parts house counterman should be able to help you.
P.S. The tstat in Whirlpools are often given in Celsius.
You'll have to convert that to farenheit
Patience in drying the machine is your friend here.
Jack..
