Sport & Outdoor - Others Logo
Posted on Aug 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just bought a winchester 308 model 100 rifle,
I just bought a winchester 308 semi-automatic model 100 rifle, and do not have a manual for it. so, how do I seperate the stock from the rest of the gun? I just want to check everything out, and give it a good cleaning. thanks for your help.
  • Anonymous Feb 02, 2012
    Remove rear **** plate with a flat head screw driver, youll need a long flat head to reach the screw holding the stock to the recoil block. Take that screw out. Remove the forearm screw, (The screw holding the forearm swivel on.) and the stock should slide forward and off.
Michael Thomas
Level 3:
  • Sport & Outd... Master 3,056 Answers
  • Posted on Aug 05, 2009
Michael Thomas
Level 3:
Answers
3056
Questions
52
Helped
1307636
Points
10935
HELLO THERE
Please go to www.winchester.com and you will be able to enter your model number and there will be a viewable manual for this and there is also telephone numbers for tech support ok>
1helpful
If I bought Winchester model 100 semi-auto how do I know the diameter .308,.243 or .308
There are 3 varients of the 100.
Model W8015 - .243
Model W8092 - .284
Model W7973 - .308
Sep 19, 2017 • The Optics
My 308 winchester semi automatic rifle jams after shooting first bullet. In order to recover, you remove the clip, eject the bullet, replace the clip, **** the rifle and shoot second shot jams
no
there is a small lip that pulls the shell out of the breach as the bolt moves back
take it in to a firearm repair shop and have it properly fixed
Oct 05, 2016 • Firearms
What is the difference in trajectory between Winchester 308 150 gr PP and the 150 gr PSP ? My rifle is sighted in for the 150 PP and I now have ammo for the 150 PSP. What will the change be in point o
this question is a bit silly since eventually you will need to resight your weapon for the new ammo anyway. So spend the time and the ammo costs to go to the range and do it right, right from the get go.
this way you won't need to recalculate drop rate and use kentucky windage for every shot at differing ranges.
Recommend from USMC sniper/rifle expert.
Sep 14, 2014 • Optics
My 308 semi-automatic rifle is jamed. i can not open the breach, any ideas this is the second time. i can not get the action out of the stock unless i can pull back the breach.
If it has an empty case in it you could slide your cleaning rod in from the muzzle and tap on it to see if this would help move the bolt back any. DON"T do this if it has a live shell in it ! hope this helps
38helpful
5answers
Winchester model 100 semi-auto 308 cal. how to disassemble?
IMPORTANT Recall info:
WINCHESTER MODEL 100 FIRING PIN RECALL - A notice dated 7-1990 relates the following
“PRODUCT SAFETY WARNING AND REPLACEMENT NOTICE. Attention owners of Winchester model 100
rifles and carbines please read this notice. In July of 1990 the following product safety
warning was issued by Winchester. It has come to our attention that the firing pin in the
Winchester Model 100 Rifle or Carbine may break due to use and metal fatigue and become
lodged in the breech bolt face. If this occurs, the firearm may fire before the action is
locked causing severe damage to the firearm and possibly injury or death to the shooter
and bystander.
WARNING DO NOT SHOOT YOUR WINCHESTER MODEL 100 RIFLE OR CARBINE. Repair and replacement.
A new firing pin has been designed to replace the firing pin originally made for the
Winchester Model 100 Rifle and Carbine. The new firing pins will be available in April
1991. If you own a Winchester Model 100 Rifle or Carbine, please send your firearm to one
of the authorized Winchester Model 100 Firing Pin Replacement Centers indicated below.
Your Winchester Model 100 firearm will be inspected, the firing pin replaced and tested
and the firearm returned to you. The inspection, replacement/testing and return postage
will be accomplished at no cost to you. If other repair or maintenance work is authorized
by you to be performed on the firearm when the firing pin is replaced, such work shall be
at your cost.”
W. R. Long Gunsmiths
2007 Brook Road North
Cobourg, Ontario K9A4W4
Canada Frank LeFever & Sons
RD 2 Box 31
Lee Center, NY 13363
USA Bolsa Gunsmithing
7404 Bolsa Avenue
Westminister, CA 92683
USA Nu Line Guns
1053 Caulks Hill Road
Harvester, MO 63303
USA
If you have any questions concerning this notice, call Winchester Product Service
1-800-852-5734 or write to Winchester Firing Pin replacement Notice, PO Box 10 Cottage
Hills Illinois 62018 Attention Product Service Dept.
The following is Wisner's rendition & info on the subject.
The difference in the old firing pin and the new one is as follows. The old replaced
style, was totally lathe tuned (round). While the new recall style is similar in lathe
turning on the front and back, but in the front midsection it has two flats milled, one
on each side. This makes the center section stronger. Also replaced is the bolt sleeve
lock pin (firing pin guide) which was made to accommodate this different shaped firing
pin
Part number for the new parts are, firing pin =1391ND, bolt sleeve locking pin =1491ND
The word was at the time this recall was in process was that if the firing pin would
break at the mid section and still remain in the gun as two pieces, the possibility of a
premature discharge before the bolt was locked was possible. This apparently was caused
by the firing pin tip (now not having a retracting spring) to be stuck forward, and
thereby slam-firing upon chambering.
The responsibility for the recall apparently was on Olin, as they were the parent company
at time of manufacture. Olin set up regional recall centers at three established US
gunshops. There was a manufacturing delay in the replacement firing pins, and a backlog
occurred, also some collectors did not like the idea of shipping their guns long
distances. Olin then also authorized other gunshops to make the required alterations.
Upon completion of the recall, the shops were to test fire the firearm and to stamp an
assigned letter on the inside top of the receiver as seen thru the magazine well with the
bolt retracted. The letter “B” represented Bolsa Gunsmithing, “L” was Lefever, and “N”
was for Nu-line Guns. The letter “X” apparently was for all the other independent shops.
However this identification information did not get communicated to some of the smaller
shops at the start of the project. The only way to tell if the gun as been modified, if
the ”letter” is not present, is to take the barrel & action out of the stock, remove the
trigger guard assembly and the try to rotate the firing pin by twisting it. If it does
NOT rotate, then the firing pin recall HAS been performed.
For link back to the parts & price list that we make & have for sale CLICK HERE
Copyright © 2004-2007 Wisner's Inc. All Rights Reserved
Back to Additional information To Winchester model 88 & 100 parts
Originated 01-13-2001 Last Modified 03-19-2007
LeeRoy Wisner
Top Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
