Health & Beauty Logo
M
Micheal Conrad Posted on Jan 08, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The head of my Wahl clippers model 9639-700 came off and I can not seem to get it back on. how does it go back on?
medypharma2148
Level 2:
Sergeant:
New Friend:
  • Wahl Expert 176 Answers
  • Posted on Feb 07, 2019
medypharma2148
Wahl Expert
Level 2:
Sergeant:
New Friend:
Answers
176
Questions
0
Helped
103855
Points
707
Buy Pulmopres 20mg online is used for Enlarged prostate gland in male, Increased blood pressure in lungs and other conditions. Know about the uses, side effects, price, composition, substitutes, How it works, Lowest Price Online. Pulmopres 20mg Online buy with lowest Price Ever Online Pharmacy. Pulmopres 20mg Reviews.
shaveroutlet.com
Level 3:
  • Wahl Master 1,652 Answers
  • Posted on Feb 05, 2019
shaveroutlet.com
Wahl Master
Level 3:
Answers
1652
Questions
0
Helped
765000
Points
4209
The head simply snaps on and snaps off. If yours is in pieces, the plastic backing is broken and you will need a new head
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jun 20, 2009
SOURCE: I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Anonymous
  • 61 Answers
  • Posted on Sep 27, 2009
SOURCE: loud buzzing on Wahl "Designer" model clippers
There is a "power screw" located on the side of the clipper opposite the switch. This may need adjusting. Take a screw driver or coin....and with the unit running......turn the screw back and forth until the clipper stops making noise. The proper position for the most power is to turn the screw intil it makes a loud noise, then turn it back just enough to get rid of it.
Anonymous
  • 576 Answers
  • Posted on Nov 25, 2009
SOURCE: my wahl clipper is very noisy, what should i do to
First, they need to have a drop of oil put on the cutters every time they are used. Second, there is usually an adjustment screw on the side of them to adjust the travel of the moving cutter. Adjust that so that it completely goes across the slots in the stationary one, but not too far or too noisy.
Anonymous
  • Posted on Dec 04, 2009
SOURCE: how to reassemble my wahl clipper model 8081
Okay, if you took this machine apart don't worry. You would have noticed when you loosened the first two screws closest to the blade (but still on the body of the trimmer) a small white part of the trimmer flew out...you were probably think wtf? Yeah, okay. If you took all four screws out, make sure you align the cord within its allocated space on the frame and screw in the bottom two.
1. Now, leave the top two screws about 75% loose so that you can slip the white piece back.
2. You will notice that there are two prongs sticking out of the hole where the blade is suppose to go. Make sure the "Detailer" enscribed on the front of the trimmer is facing the ground (or opposite yourself). Align the white piece so that the groves are facing the prongs and the other half of the white piece is facing yourself.
3. Slide the white piece down as far as reasonable, without forcing it. There is a little hook on the white piece, and a corresponding groove on the casing of the Detailer. Make sure that you align the white part so that the hook aligns with the groove, also make sure that you have aligned the groove on the back side of the white piece with the small round tip of the motor.
4. Okay, so this is the tricky part, you will probably be saying...the white piece is still sticking out. Well this is initally why it flew off when you took the machine apart. The blade acts a spring load for the white piece and the top two screws on the casing holds the remaing pressure forced on the white piece. What you need to do now is align the blade and its screws with the corresponding holes on the maroone casing and push the front of the blade down on the white piece and tighten the screws. The machine should now be working.
Hope this helps.
Anonymous
  • Posted on Nov 17, 2010
SOURCE: WAHL model MC. Very loud (mechanical)
Should have a flat head screwdriver handy... on the side of the clipper there is a dial where you can insert the tip of the flat head.. Turn on the clippers and turn that knob with the screwdriver slowly till it hums nice and even..
1helpful
2answers
How do I use Wahl hair clippers? How do I know
Hi I have been a hair stylist for 25 years each guard that clips on has a number on them the lower the number the more hair is clipper off start big like a number 8 will leave one inch of hair 7 leaves 7/8 of a inch 6 leaves 3/4 of a inch 5 leaves 5/8 of a inch 4 leaves a 1/2 inch of hair on the head 3 leaves 3/8 of a inch 2 leaves 1/4 of a inch and a 1 is just hair on the Scalp almost bald no days the color of guards are changing so your best bet is go with the size remember to start with the largest one first then you will know what you like the best and you can't go wrong and if you buy WAHL and you not A Hair Stylist You Can Purchase A Good Clipper at Sallys Good Luck
7helpful
WAHL model MC. Very loud (mechanical) buzz when on. May be clipper blade out-of-adjustment (?) Do not have instruction manual on how to adjust.
Have lost charger and battery number for model number9918 please help
from the picture you have here, That I see you have a Wahl 8554 Wahl Alpha cordless clipper. but you stated the model 9918-6171 Groomsman Beard and Mustache Trimmer model, You need to be sure of what model you have. He are the two picture of each model. if this is correct, Mannys Sharpening has the charger for this cordless clipper, I had the same problem and he sent me one it took about 2 weeks for delivery.
27a92b7.jpgThe clipper on your Left is Wahl 9918
3283d36.jpg This clipper is the Wahl Alpa 8554 cordless
Call Mannys Sharpening he has all the replacement charger for Wahl.
323 263-4697
2helpful
Wahl Razor will not realign after removing blades for cleaning!
This is always a problem with clippers, it's just a matter of holding the blades tightly in place and getting the screws in as tightly as possible without letting the blades go. This has always worked for me in the past.
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
