SOURCE: Have connected an Apple TV
This television is most likely unable to decode, process or downgrade the signal so that you can get sound out of your surround sound system from it when viewing Apple TV. You would have to be use a fiber optic cable between the Apple TV and the surround sound system. If the surround sound system does not have a digital audio input then it coud also be the surround sound system itself that cannot decode, process, or downgrade the signal coming from the Apple TV in order to project any sound.
SOURCE: Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
SOURCE: Philips HTL5120 has no sound when using lg tv 50lb6100 youtube/netflix apps
There isn't a firmware upgrade for this TV is there? Sounds like a firmware issue?
SOURCE: how to connect my tv to optical outlet
What audio-outputs does your TV have? SPDIF? 3.5 millimeter stereo-jack? White/Red RCA "post-and-collar" sockets?
What inputs does the sound bar have? (Same choices as above.)
Note that you might need a 3.5mm to stereo-RCA cable.
