I contacted their tech support and this is part of what I got back. As you may know, our old legacy vSpace versions reached End-of-Life status in Jan 2018. This, as well as information on all our products, can be found on the product lifecycle page https://www.ncomputing.com/support/lifecycle Part of the shutdown process for our expired legacy software involve decommissioning servers that perform online registration for legacy vSpace versions. This will have no effect on your current installations, however, after the specified date, new online registrations for the old legacy vSpace versions will not be possible.
SOURCE: Dear Mr. , I have VMware
Hello Rana,
Please recheck which model number you are working with, since what you are describing sounds like the L300 and not the L230. If it is the L300, then you may have initiated a firmware update from the console or from within the device. We'd be happy to walk you through this -- please contact us online or by phone by going to: http://www.ncomputing.com/techsupport
SOURCE: NComputing vSpace not installed my pc Error
Options:
(A)
An authorization error usually occurs when more than one system in a
LAN has the same software serial numbers assigned to the system. In
this case, the first PC to be turned on does not suffer an authorization
error, but any subsequent PC's which contain the same serial number will experience the issue.
To remove these duplicate serial numbers, first unregister them, then delete them from the host PC they are installed on:
Also, an update
that does not install correctly may rarely cause corruption of the data
file in which serial number information is contained, causing this
error. If there are no other X-series hosts on the network with
duplicate serials, then a complete uninstall and reinstall of the
X-series software may fix this issue. When uninstalling, choose to
unregister all serials and remove all serial registration data.
To download the latest version of our software, please search the knowledge base using "software download" as the search text, for links to the latest software.
(B)
When more than one X300 station
is used under the same login (same Username on two or more stations),
Active Desktop error messages may occur. Also stations would be sharing
same user settings and other files, which could cause unpredictable
errors.
Different stations should always be used with different usernames
logged in. To add more User accounts (usernames), go to Windows Control
Panel, select Users and then go to Create New User option.
