Boating Logo
D
Dianne stafford Posted on Jan 08, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How old is Grumman 16 ft with CSS on side. Where is the vin number
Jean DeLauche
Level 3:
  • Master 2,911 Answers
  • Posted on Jan 08, 2019
Jean DeLauche
Master
Level 3:
Answers
2911
Questions
Helped
975784
Points
13030
Hello, Dianne -
Boats have been required to have Hull Identification Numbers (HIN) since 1 Nov 1972 in the USA.
Go to this web page to learn where the HIN should be found on your Grumman boat, if it was made on or after 1 Nov 1972:
http://www.hinsearchplus.com/hs_userguide.aspx
Once you find the HIN, the information on the web page should help you determine when your boat was made.
Best wishes.
Please can you help with all the torque settings for the cylinder head on Hyundai Accent 1.5 1995"
Nissan Frontier, Xterra 1998-05
Torque Specifications
Fig.
TORQUE SPECIFICATIONS
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1998 2.4 (2389) KA24DE
1A Step 1: 22 ft. lbs.
2B 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
4C The cylinder heads and the lower intake manifold are installed together
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1999 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 3.3 (3277) VG33E
1A The cylinder heads and the lower intake manifold are installed together
3C Step 1: Tighten the cylinder head bolts to 22 ft. lbs.
4D Step 1: Tighten the connecting rod bearing bolts to 10-12 ft. lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1998 KA24DE
1- Step 1: 22 ft. lbs.
2- 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
3- The cylinder heads and the lower intake manifold are installed together
4- 10-12 ft. lbs. +60-65 degrees
5- Step 1: 72 ft. lbs.
6- Step 1: bolts 11-22 19 ft. lbs.
7- Step 1: 20 ft. lbs.
8- Step 1: 31 ft. lbs.
9- 83 inch lbs.
10- Stud bolt: 11 ft. lbs.
11- Step 1: 72 ft. lbs.
12- Bolts: 17-24 (M8) 16 ft. lbs.
13- Step 1: 33 ft. lbs.
14- Intake manifold collector:
15- Intake manifold:
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1999 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2000 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2001 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2002 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2003 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2004 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2005 QR25DE VQ40DE
9- 83 inch lbs.
Main Bearing Torque Sequence
Fig. Main bearing torque sequence-2.4L engine
Fig. Main bearing torque sequence-2.5L engine
Fig. Main bearing torque sequence-3.3L engine
Fig. Main bearing torque sequence-4.0L engine
How many people are allowed on a 1989 Grumman 24 ft pontoon.
Should be a manufacturer plate located on the unit that recommends designers speck for this... it is either a sticker or a brass plate .. One should be around the hell and one by the rear.
Apr 10, 2018 • Boating
2answers
Where is the engine number on. 2011 Jeep Liberty Sport? I need the engine number, not the VIN.
Contact the parts dept with a Jeep dealer. Provide the vin number to them and they can tell you everything about your vehicle.
Where would find the fuse or relay for the flashers
I would first suggest that you obtain and run the VIN number of your vehicle on any of the Internets free VIN number searches. From this you should be able to gain the exact year and model number of your vehicle and getting the info you need from their should be pretty easy. Most VIN numbers are located down in between the iner or outer front windshield drivers side and dashboard windshield washer slot areas ... It will be a number around 14 to 16 numbers long .. Cannot miss it when you see it ... Sincerely Richard
1helpful
I recently changed my fan belt & installed my old thermostat back on my grumman 85 &now my temperature gauge don't work but i got heat what could be the problem what should i look for?
wonder if you knocked of a wire plug that is the heat sensor while working on your grumman 85 .
see this video for what it looks like on a car
https://www.youtube.com/watch?v=fWjPX0_ibxY
https://www.youtube.com/watch?v=i2Kd0VQWw1o
1helpful
I want to know in what year the bike with this vin number was manufactured
well in the good old USA if you have a 16 digit VIN number then the 10th digit will always denote the model year of the vehicle and that applies to all vehicles with a 16 digit VIN. The coding for them simply starts with the letter H and they leave out a few choice letters such as I O Q Z and then it starts into numbers after Y and honestly after the year 2009 Im not sure what they have gone to as Im not currently working in a dealership anymore, however here is a chart that I made to help ya get it figured out. Good luck and enjoy your summer.
h = 1986
j = 1987
k = 1988
l = 1989
m = 1990
n = 1991
p = 1992
r = 1993
s = 1994
t = 1995
u = 1996
v = 1997
w = 1998
x = 1999
y = 2000
1 = 2001
2 = 2002
3 = 2003
4 = 2004
5 = 2005
6 = 2006
7 = 2007
8 = 2008
9 = 2009
May 21, 2010 • Motorcycles
5helpful
2answers
Need torque specs for 83 chevy 350 cylinder head bolts.
Hello there
Torque Specs
These specs may not be correct for your application.
Verify your engine specs with a service manual for your year and model.
always torque bolts in three equal increments
Bolts or Parts Lube or Sealer Torque to: 7/16 Main Caps (2 bolt) Engine Oil 70 ft-lbs. 7/16 Inner Main Caps (4 bolt) Engine Oil 70 ft-lbs. 7/16 Outer Main Caps (4 bolt) Engine Oil 65 ft-lbs. 3/8 Outer Main Caps (4 bolt) Engine Oil 40 ft-lbs. Warning!!! If you are using ARP bolts, you MUST use
their specs. Click Here! 3/8 Connecting Rod Bolt Engine Oil 45 ft-lbs. 11/32 Connecting Rod Bolt Engine Oil 45 ft-lbs. Cylinder Heads
Engine oil
(blind hole)
Sealer
(water jacket)
65 ft-lbs.
Rocker Studs (screw-in) Engine Oil 50 ft-lbs. Oil Pump Engine Oil 65 ft-lbs. Oil Pan Engine Oil 12 ft-lbs. Cam Sprocket (upper gear) Thread Locker 20 ft-lbs. Timing Cover Engine Oil 6 ft-lbs. Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer 30 ft-lbs. Valve Cover Engine Oil 3 ft-lbs. Exhaust Manifold Anti-Seize Lubricant 25 ft-lbs. Spark Plugs No Lube or Sealer 20 ft-lbs. Flexplate (Automatic)
Flywheel (Clutch)
Thread Locker 60 ft-lbs. Clutch Pressure Plate Thread Locker 35 ft-lbs. Centerbolt
(Harmonic Damper)
Engine Oil 60 ft-lbs. Bellhousing
(Transmission to Block)
Engine Oil 25 ft-lbs. Head Bolt Tightening Sequence
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
