Question about Beko Washing Machines
Hi everyone, how can I get into service mode in my BEKO WYA81643LE washing machine? Thank you
  • 5 Answers
Start by turning the washing machine of with door shut.
Now turn the dial to the position 1 Which is normally the 90c hold the start /pause button down while you press the on/off button to on for a couple of seconds till light flashes
Now turn the dial to the position 6 and hold down a few seconds the next time you enter it should turn on all the lights now you are in self test diagnostic mode:
Every time you Press the on/off button it will change the test function.
1st all the lights will show
2nd will not do anything
3rd This will tell the motor to turn at standard wash speed clockwise with pump emptying.
4th This will tell the motor to turn at standard wash speed anticlockwise with pump emptying.
5th This will tell the motor to spin clockwise with pump emptying.
6th This will activate right hand compartment water valve. Please note machine will keep filling until you stop it.
7th This will activate left hand compartment water valve. Please note machine will keep filling until you stop it.
8th This will activate booth water valves together. Please note machine will keep filling until you stop it.
9th will not do anything
10th this will start fill cycle until water activates the pressure switch at normal fill level (Normally just below the glass on the door) when the Beko washing machine has reached the level it will start clockwise rotation at normal wash action and heat the water. Please note You Have to stop it manually.
11 this will activate the pump only to empty.
Press again and you are back at the start. Turn machine of and leave for a few minutes and the switch back on and you're in normal wash mode.
Posted on Jan 12, 2019
  • 1462 Answers
SOURCE: Hi, I need to find
press start/pause/reset button for about 10 secs
Posted on Jul 05, 2008
barkencoa
  • 3463 Answers
SOURCE: how to change brushes on beko washing machine
remove rear cover of washer, locate and remove belt.
Unfasten motor ,disconnet motor lead, and remove motor.
Brushes are located at opp end to motor pulley.
Replace if less than 5mm long.
Plz rate my solution.
Thanks
Posted on Jan 21, 2009
  • 44 Answers
SOURCE: beko wma641w reset
hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
Posted on Mar 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: instruction manual for a beko 1512s eco care washing machine
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!
Posted on Sep 16, 2010
sharon2610
SOURCE: how to reset or unlocked the beko washing machine timer
My washing machine time delay switch is flashing and I can't turn the machine on what do I need to do?
Posted on Sep 05, 2012
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
I need to buy the instruction booklet for the beko WMA 620 W washing machine.
This is the link where you can download user manual for BEKO-WMA 620 WASHING MACHINE
http://www.2instructions.com/results_mm.php?materiel=Washing%20Machine&marque=BEKO
hope this helps you,thank you
Feb 08, 2011 | Washing Machines
replace the timer not sure where you will get a service book from replace one wire at a time when you change the timer.
Mar 28, 2008 | Washing Machines
Beko 520w wasing machine
Hi see the last video on this it will show you test mode or if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Mar 08, 2008 | Washing Machines
Washing Machines Logo
Top Beko Washing Machines Experts
micky dee
janman
john h
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
