Question about Roland Computers & Internet
Hello Sir, my Roland comes on and goes through the mode of booting up but does not have any sound?
Led light is not bright enough to see the image screen is in over drive mode ,can only be seen by certain angles.
SOURCE:
Shuttle83
  • 1139 Answers
SOURCE: Display light is dark
I have seen this problem before this is caused by a failure of the backlight which provides illumination for the LCD screen. You may also want to check the inverter also since it fails often and interacts with the backlight.
Posted on Sep 04, 2007
  • 13 Answers
SOURCE: Gateway 400SD4 Power Problem
Faulty Battery.
Get a new one.
If that is not the problem check the ram.
Posted on Jul 01, 2008
motor1258
  • 6674 Answers
SOURCE: Oil light comes on at certain times
You did check the oil level parked on level ground right? My guess is that your level is either low, or your sensor/oil pressure switch, is getting too sensitive, and may need to be changed. Unless you've changed grade of oil lately. When you stop, your oil in the pan, shifts forward in the pan & starves the oil pick-up momentarily, so if your switch/sensor for oil pressure looses pressure too much during that time, it turns on the light. If your due for an oil & filter change, have it done & make sure it's up to full mark on level ground.If that doesn't cure it, I would change oil pressure switch, oil sender, or oil pressure sensor, whatever it is referred to on your vehicle.
Posted on Dec 21, 2008
Geekman
  • 32281 Answers
SOURCE: Dell inspiron 6400 display goes off < 1 min after switch on time
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
The buzzing sound is most likely the inverter problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 26, 2009
pumpkinman
  • 1165 Answers
SOURCE: VGN-FS640W - Three green LED's come on but no boot up.
your hardrive is going bad cannot read the disk.take hardrive out and tap it slightly? then replace see if it makes a difference..
Posted on Jun 17, 2009
How can I repair my LGSMART TV?
hi sounds like failed led or leds in the panel, thanks
shaun
Mar 02, 2017 | Televison & Video
Hello! I have a samsung un32c6500 LED tv with a
Do you have sound? If you have sound and if the TV is responding to commands then I would say the main is fine. However if you don't have sound or video I would start with the power supply voltages. If you have sound and no video, I would suspect t-con but be advised, some manufacturers are building the t-cons into the panels !!!
Nov 02, 2013 | Samsung UN32C6500 32 in HDTVReady LCD TV
I have roland verscamm 540v when i sub switch on
hello m f azam
have u solve the problem already?
Aug 20, 2013 | Roland VersaCAMM SP-540V
Laptop on but screen black
Have you cleaned the fan, vents, heatsink recently? Does the Laptop overheat? Is the Laptop booting? Fan spins? Sound? LED's blink? I can tell much from the video. In a bright light can you see a "ghost image" of the desktop? Do you feel comfortable opening the Laptop? If so, there are a few things you can check.
Apr 27, 2013 | Computers & Internet
No image 0n screen
Do a Cold-Start, remove any media, DVDs, CDs, USBs, printer cables, etc, unplug, remove battery, leave out during this process, plug in push on/off button, immediately start tapping ctrl+F-11 repeatedly until you get a beep or open the restor/recovery. restore to a date before this issue. You say "Boot up computer", does it boot?, HDD led blinks?, sound? Is there a "ghost image" in monitor under a very bright light? Has the laptop been damaged, dropped, jarred........etc? There is a tiny switch the turns the monitor on and off when you open and close the lid. It can get stuck. respod to this post for further assistance.
Nov 19, 2012 | Dell Inspiron 1501 Notebook
Aluratek at107f , unit won't boot up
Had the same problem with mine the other day. Go outside in the sunlight or use a flashlight. Touch the menu hard key. you should hear it click. Using the bright light, click on settings, go to display, and turn up the brightness. I know this sounds elementary but for what ever reason, this device, when it goes into sleep mode, will adjust the brightness settings down. Hope this works for you.
Nov 15, 2012 | Aluratek AT107F cinepad-4gb-7-tablet
I have acquired a night owl monocular nightscope. the only number I could find was in the battery compartment # H3T-3M. there was a serial # 9846786. The problem appears to be the switch. the powerligt...
Yes, If you turned the Night Owl on during the daylight hours, or looking directly into bright lights.
If you have done this more than few time it could have damaged the image intensifier tube. If this happen to many times, it's finny, kaput, so long, it gone south, and gone bye-bye.
Looking at bright lights is damaging to NV devise. The intensity plate in the image tube, magify the existing light about 3000 to 8000 (radian light from the stars, moon and other light sources).
You have 80mm front lens on the Night Owl NOCP5. This mean that more light can inter into image tube.
Sir, have you been looking at bright lights, operate NV system during the day, have you? If not, there could be something else worng with you Night Owl. stewbison
Mar 07, 2011 | Night Owl Optics Cyclops Pro NOCP5...
Cmi8738c3dx sound card causing PC to hang up to welcome/logon screen
Check whether the sound card drivers compatible with your present operating system. if your Pc built with Vista OS. then Get a vista driver from its official website.Some times When you install any devices or driver that might change the system files. even it may corrupt the files due to its incompatibility. Some mother board and Bios does not support some type of Sound cards . if your Motherboard has onboard audio .then disable it through Bios utility. uninstall the sound card,drivers. Remove the Sound card. REplug it. Restart the Pc. this time you can get add new hardware window. install the drivers. if problem still persists contact service centre.
thank you !
Dec 24, 2007 | Genius Soundmaker Value 5.1
Computers & Internet Logo
22 people viewed this question
Top Roland Computers & Internet Experts
Harrie
Tom Chichester
ray gallant
ray gallant
Are you a Roland Computer and Internet Expert? Answer questions, earn points and help others
