Refrigerators Logo
Joe Smith Posted on Jan 08, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gfe29hsdss Is freezing food in fridg compartment & ice accumulated under the fresh food compartment
Pablo
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Jan 08, 2019
 Pablo
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
21913
Points
63
Usually a bad air circulation cause ice acummulation around the fan. Try to defrost the fridge to see it solve the problem. Good luck.
Chris Huff
Level 3:
Top Expert:
  • GE Master 6,289 Answers
Chris Huff
GE Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2019704
Points
74913
Food freezing in fresh food compartment is most likely a bad thermostat/ control board, or a damper that’s open too much.
5 Related Answers
Anonymous
  • 72 Answers
  • Posted on Jul 11, 2007
SOURCE: The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Anonymous
  • 89 Answers
  • Posted on Dec 02, 2008
SOURCE: my frdge compartment is freezing
Pehaps the damper door motor is burned out or the damper door is just stuck open causing to much air to flow into fridge side. Damper door is located at the very most top-back-left corner of the "fridge" side.... goodluck...
Anonymous
  • 531 Answers
  • Posted on Apr 01, 2009
SOURCE: Amana BRF20 - freezing in fresh food drawers
check your door not closing stay (ajar)
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on May 04, 2009
SOURCE: refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
Anonymous
  • 389 Answers
  • Posted on Apr 21, 2010
SOURCE: brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
2answers
Freezer set at 0 fridge set at 37. thngs in fridge and crisper are freezing
this is a big problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Puddles of water in the fridge
OK that sounds like Ice may be blocking the defrost condensate drain. I will need your model number to help me to identify your model better but can leave you with some information about water leaking inside the freezer or fresh food compartment. Sears use a model number found around your door frame and looks like this for example 312.56989 Be right back with some links, Thanks Sea Breeze
My side by side freezer is working fridge wont get cold,compressor is working.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require a service technician to check and repair these components.
Hope this was helpful. Good Luck.
Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
1helpful
Maytag bottom freezer Model MBF2254HEB not blowing cold air into freezer or fridge, blows warm air if blowing at all, starts and stops. Any suggestions? Possibly a reset button somewhere? Thanks - Kurt
Fridg is not working right
Working fridge, warm freezer.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
3helpful
Fridge doesnt stay cold
2helpful
2answers
Coils keep freezing up its 4 years old
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bough a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
The coils on my ge gss22wgpd bb side by side keep freezing up . IU can defrost them manually and the freezer and fridge work fine again.
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
This site has schematics of various appliances, including the model number you provided...
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=GSS22WGPDBB&mfgModelNum=&fkMfgID=2
Your model appears very similar to mine - in the "Fresh Food Shelves" section of the above site, the sensor is diagram number 242. In the "Freezer Section", the sensors are diagram number 241 and 243.
Top Refrigerators Experts
vince
Johnny 1000
