Question about Sanyo Televison & Video
I need the code for sanyo lcd tv model lcd 46xr10f
    Top Expert:
  • Sanyo Master
  • 51,327 Answers
The applicable code would be found in a compatible remote control.
Posted on Jan 08, 2019
SOURCE:
SOURCE: need codes for a Sanyo TV
I have a 15-2147. The codes from solution 1 didn't work for my remote, so I used the codes listed on Radio Shack's page for the 15-2142. The first code worked. Those codes are: 0154, 1907
Posted on Jan 08, 2008
  • 7 Answers
0049, 0097, 0110, 0004, 0268, 0012, 0108, 0180
Posted on Jul 30, 2008
Code for Sanyo TV is 0154
Posted on Mar 26, 2009
enov8
  • 53 Answers
SOURCE: Need Remote Code to program Sanyo TV for remote model RC24977-0
Try these (4 digit codes)
SANYO.............0049, 0097, 0110, 0004, 0268, 0012, 0108, 0180
Posted on Apr 23, 2009
SOURCE: Sky Remote code for Sanyo LCD TV
I HAVE FOUND THE CODE AND SKY NEVER HELPED THE CODE IS AS FOLLOWS DEPENDING ON HOW OLD YOURE REMOTE IS 0065 IF YOU HAVE AN OLD REMOTE TAKE THE FIRST ZERO AWAY
Posted on May 01, 2009
What remote codes do we need to connect remote to Sanyo TV model 3264B 2008.
Mary, Universal remote codes for Sanyo TV model 3264B Check the attached links,instruction and guides containing 3 and/or 4 digit codes, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://codesforuniversalremotes.com/universal-remote-control-codes-sanyo-tvs
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
Apr 26, 2016 | Sanyo Televison & Video
Hello Brett, recently I was given a SANYO LCD FLAT SCREEN TV MODEL:LCD-46XR10F; 46 INCH SCREEN MANUFACTURED OCTOBER 2010 BUT it had no Manual so need help to acquire one please. Rowena
Manual U get from the manufacturer web site.
The tv does not record the program. That is done by a dvr and then PLAYED back on the set.
Mar 10, 2016 | Sanyo Televison & Video
My 46inch sanyo lcd 46XR10F has half a screen with pitcure and the other half all black or coloured lines. I have sound.how to fix ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 06, 2016 | Sanyo Televison & Video
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
What is the sanyo 46xr10f 5 digit code for universal remote
0029,0020,0021,0026.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 13, 2014 | Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
Need a remote code my new sanyo tv to go with att-uverse cable sanyo #dp19649
I went through all the Sanyo TV codes and then started entering in groups of 10. The U-verse offered 1103 i did 1100 to 1110 and it worked with 1107. Unfortunately at&T said you have to check the manufacturer which doesn't list universal codes. I was lucky on the Sanyo 18.5" LCD from Walmart using 1107!
Aug 31, 2009 | Sanyo DP19647 19 in. LCD TV
Televison & Video Logo
37 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
