Question about Nintendo Video Game Consoles & Games
How do I get my things back if I got a new Nintendo switch
I got a Nintendo switch but we changed it for other one because the first one had a problem in the charger so we changed it and got a new one but when I joined my Nintendo switch account and started playing I noticed I didn't have my things that I had before like in super smash bros I didn't have my fighters and in Zelda I didn't have my missions in both games the game was in the beginning and I don't know how to get my things back can you help me please
    Master:
  • Nintendo Master
  • 818 Answers
The TOTY start yesterday, and the strikers were announced, the packs opening on https://www.fifacoin.com/futtot?aff=222703 will be available soon, good luck to you.
Posted on Jan 08, 2019
SOURCE:
jawsv20
  • 3 Answers
SOURCE: How to save games?
Successfully complete the game to get the option to save your game anywhere. When you start a new game, the "Save" option will be available under your menu in the map screen.
Posted on Jan 25, 2009
BelgianAlien
  • 50 Answers
SOURCE: Wii console states that it cannot read Super Smash Bros. Brawl
Will your game disc play on your neighbor's console? If it does not, then you might have a bad disc. Take your receipt and the game back to the store, they will exchange a game for the same title, with receipt.
Thanks for using the FixYa forums!
Posted on Mar 31, 2009
yrrtu
  • 28 Answers
SOURCE: Wifi problems with Wii and Smash Bros. Brawl.
Fiend your solution direct from Nintendo. Here is your solution....
http://www.nintendo.com/gameboy/prob676ijt65/solution
05
Posted on Apr 04, 2009
  • 4 Answers
SOURCE: New super mario bros. Nintendo Ds Lite game
To walk through the world 4 and 7, you must won the 3rd and the 6th castle with mini mario.
Posted on Jul 22, 2009
XtremeNights
  • 22 Answers
SOURCE: I bought Super Mario Smash Bros Brawl game for
The reason for this is that the "eye" in your Wii to read the disc is too dusty to read the disc, as it is a 2 layered disc. Call up Nintendo and ask them for help, they will tell you what to do and they will clean out your Wii for free.
Posted on Nov 30, 2009
Tip
Reset your Wii Video Settings to the Default
One annoying thing about the Nintendo Wii is that there is no way to reset the video settings once you have changed them in the Nintendo Wii System Menu.
It will not detect which cables you are trying to use and just tries to use the last settings that you set it to.
So, if you have changed your Nintendo Wii from using the regular cables that came with the system to using component cables, then switch back to a TV using regular RCA cables (these are the yellow, red and white cables) then you need to reset the settings on your Nintendo Wii to the default video settings.
You can reset your Nintendo Wii video settings to use Composite (or RCA - Yellow, Red and White) cables by doing the following:
1. Make sure the Nintendo Wii is powered off and a red light is showing.
2. With the power off, unplug the video cables from the back of the Nintendo Wii, leave them plugged into your TV (these should be the RCA/Composite cables)
3. Press the Power button on the front of Nintendo Wii. Make sure the cables are still unplugged.
4. Keep the Nintendo Wii powered on and plug your cables back into it with it still running.
5. If all went well, the picture should appear normally now.
6. Once the picture has reappeared, you should go into the Nintendo Wii Menu (the Wii button in the bottom left hand corner) and change the display back to 480i to make the changes permanent.
I hope this tip helps!
on Apr 09, 2010 | Video Game Consoles & Games
Hoe do i change my nintendo ds game slot
You must remove the bottom of the DS. There are security screws that need to be removed. It takes a special screw driver to remove them. There are also 3 or 4 regular small phillips head screws that must be removed. Then the bottom can be removed. Be careful not to break the power switch off when removing the buttom. Once the bottom is off you can see the slot and unsolder it. You will need really good desoldering and soldering skills and the pins that will need to be removed and resoldered are small. You'll need a very small tipped solering iron. You won't find one small enough at radioshack. You'll have to order one special from a store online. Once you have the new slot put in you then just put it all back together in reverse.
Feb 06, 2010 | Nintendo DS Lite
My ds is not turning on
check battery replace if need be, check that the switch springs back when moved up, try turning it on with the mains cable plugged in. Still no joy change fuses on the motherboard and eventually if nothing changes its a new motherboard or ds.
Jan 12, 2010 | Nintendo DS Lite Console
New battries in board, pressed synch button, still not working, also havnt used for while
This could be one of two things.
If you are useing an hdmi cable, make sure it is pushed into the back of the tv and console correctly.Or it could be a fault with the rf board, that is the board that is behind the on/off switch on the front of your console, if this is the problem you will have to remove the case to change this part, they cost about £5 off ebay.
Hope this helps.
Jan 09, 2010 | Nintendo Wii Console
Problem with the game cards
You need a new cartridge game reader.. Or.. If you're not doing this..
Insert the game, and cut the game on with it inserted and see if it reads.
May 26, 2009 | Nintendo DS Lite Console
Brand new Nintendo DS Lite and the power switch is loose so can't turn it on. Any suggestions?
Since its brand new, just go to Nintendos website fill out the form mail it back to them and they will fix for free. Start here: http://www.nintendo.com/consumer/systems/selectds.jsp?type=system&symp=s3B
Good luck.
Nov 15, 2008 | Nintendo Computers & Internet
Wii wont switch on
hi the same sort of thing happend to me i put a new fuse in the plug it is ok now try it if not take it back.
Oct 12, 2007 | Nintendo Wii Console
Nes Nintendo Channel Trouble
are you using a/v (audio/video cables with rca ends), or direct to cable input on t v.? if direct to t v, did you check ch switch on back of system deck? otherwise is t v programmed for the correct INPUT. T V, AV1. AV2. OR AV3? ANOTHER PROBLEM WITH OLD NES IS YOU MUST CLEAN THE GAME EVERYTIME YOU INSERT IT. TO CLEAN MIX ALCOHOL/WATER 1-1 AND USE QTIP. RUN IT UP AND DOWN BOTH SIDES OF CONTACTS. IT WILL DRY RIGHTAWAY.
Sep 19, 2007 | Nintendo NES Console
Video Game Consoles & Games Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
