Question about Kohler Plumbing
Hi I am having trouble removing the kohler 304 pressure balancing valve Can I force it by turning it with pliers?
    Top Expert:
  • Kohler Master
  • 51,383 Answers
Only if you don't mind having to replace the valve after you finish forcing it with pliers.
Posted on Jan 08, 2019
SOURCE:
  • 49 Answers
SOURCE: grohe trim pressure balance valve
i looked at it and there might be a press in cap with a screw underneath where the grohe label is. there also may be a set screw around the shoulder of the handle where an allen hex wrench fits to losen its clamp on the stem. also.......some handles just snap on and just pull off with some tugging and wiggling them just right.
Posted on Jan 23, 2009
  • 23 Answers
SOURCE: Kohler K-12177 low water pressure output. Removed
check valves under sink make shure tey are all the way on but spray them into a bucket if you can to see if they are ok.
Posted on Oct 31, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Kohler
The problem is that the pressure balance unit is stuck...therefore no hot water...it is not sensing the cold water pressure....so it will not allow hot water to flow...
The lack of use is actually a bad thing as the rubber and such can adhere to the metal and stick the unit...
You maybe able to free it up, but it probably will never work correctly...
I would just replace the pressure balance unit to be sure that it is working correctly and safely...
heatman101
Posted on Jun 23, 2011
bigguy810
  • 448 Answers
SOURCE: kohler shower valve trim on temptrol mixing valve
all mixing valves are the same if you have one in you can change the guts or you can install a new one in a different location i have allways installed them at the hot water heater it makes things easy to service or replace
Posted on May 23, 2012
  • 7 Answers
SOURCE: Kohler toilet troubles
The holes around the inside of the bowl may be clogged, try using some CRL and scrubbing the holes with a good stiff brush.
Posted on Apr 09, 2014
Cold water going through to hot side
Replace pressure balancing spindle part number 500520 from Kohler, if you purchased part Kohler warranty may cover issue, Kohler Customer Service 800-456-4537
Apr 09, 2014 | Kohler K-2971-KS-NA Hiflow Rite-Temp Valve...
My water pressure drops when I turn temperature to hot. And the temperature changes throughout the shower. What could casue this?
Hi! The problem may be the pressure balance cartridge needs replacing. I have seen trash (small rocks -a piece solder-Teflon tape-rust from pipes) cause this problem, but you will have to remove the the cartridge to find out.
May 21, 2011 | Kohler K-T14420-3-SN Polished Nickel...
I have a Kohler cistern, on the back of the lid it has the following marking:JACOB DELAFON BE 1082. It is currently overfilling and I need to replace a little rubber washer which I presume is under the...
you can try to remove it or you can go to a plumber supply shop and get a new level controller
faster easier and gives another 10 years of service
you may have to remove the unit from the cistern to get enough force applied to turn the cap so the job is half done anyway
Aug 05, 2017 | Kohler Home
Can I solder the threaded copper adapter to the valve housing? I installed a Kohler K304 (Failed to use teflon tape on the hot side copper threaded adapter). It is all installed and has a slight leak at...
I wouldn't risk it in case you ever need to remove it.
I would drain the system down, take it off again and refit with tape or a sealing compound such as Bossfix.
Feb 23, 2011 | Kohler K 304 Rite Temp Pressure Balancing...
Need to replace a moen tub-shower valve without tearing down a wall. Can you help? Where can I get the valve?
If you remove the handle and the fasia plate you'll see the valve in the center (make sure to turn off the supply valves first. These are located at 3:00 and 9:00 beside the valve. Then the whole assembly unscrews from the center with a large adjustable wrench or a pair of channelock pliers.
Feb 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Kohler shower facuet pressure balancing problem?
ever since the pressure balancing regulations came out for shower valves, they have went from simple to very complicated devices. sounds as if some foreign material caused the valve to stop working. that valve is quit difficult to reassemble correctly because there is only one way it works and can be assemmbled many ways that do not work concerning alignment of the ports. if you dissassemble it and check that all the moving parts are functioning in the balancing cartridge you can then look closely at the alignment of the ports on the cartridge that the handle is connected to. understanding how the port align as the handle is turned should assist you in assembling it correctly......hope this helps.
Jan 20, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Dec 30, 2008 | Kohler K-T10335-4-CP Lyntier Rite-temp...
No water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Dec 25, 2008 | Plumbing
Plumbing Logo
106 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
