HP manual shows removal of HD but manual is generic & the inside of my 350t does not look like what they're telling me per generic manual. I have remove the top two screws and push down what looks like the holder at bottom of cage but it seems like it's welded in! The generic installation manual for the pavilion elites shows a different inside than mine. I can't find one that shows the inside of my pavilion 350t
Hpe-350t???????????????????????
ok , u had trouble at HP.com that it/.
not stated who gave you the wrong manual
the manual is called service or maintenance.
posting without the full service tag data is FAIL.
we cant guess what it is nor WHAT IS INSIDE.
IT SOLD CTO, CONFIGURED TO ORDER. A FACT
MOST PRO (elite or enterpise PC desktops made)
or workstations have special HP, (in this case) hdd base
https://support.hp.com/us-en/product/HP-Pavilion-Elite-HPE-Desktop-PC-series/4162190/model/4242522/
is this it, we don't now, and has full long model numbers.
is the upgrade service guide, lacking these facts?
IDK.
all my HP, z600, xw4600 and more all have snap rails.
for the HDD. see green levers, bingo,snap rails.
page 18 ,the most simple and clear instructions on earth.
even photos step by step
my guess step 7 and 8 blows you away, sure.
yes the front panel snaps off.
there you go , hpe-350t (had to guess full model)
OP?
if confused>
post that desktops, service tag here.
then we can match all things to IT.
not like you did, with generic docs.
ok>?
did you loose this?
http://www.pcdied.com/TAG-jive/hp%20tag-...
each number there has MEANING
HP makes 1000s of desktop models (30 years)
530t is not complete !!!
There is a lever you have to press down
have a look at this amusing video on how to remove the hard drive
https://www.youtube.com/watch?v=5Cn1N04q804
SOURCE: hp pavilion 8760c has a
but the u can figure it out its simple.u might need to use alil more force after sliding the tab.if still wont come out slide the other way and it should slide out
SOURCE: I want to remove the hard drive from an HP
Make sure your computer is turned off.
Open up the case.
The hard drive will be hooked up with two cables, a power cable and a data cable.
Unplug both cables, unscrew the mounting screws, then pull the hard drive out.
SOURCE: remove hard drive from HP Pavilions a6230n
No you have to remove the media drive cage from the front the panel comes off. then pull on green tab to remove it completely then you'll be able to reach the harddrive
