Says "New SMS 160/1 En" on blue band at top of screen. When I tap a key green letters appear under text message box and a green arrow is pointing to fight side of screen. Thank you.
SOURCE: how to delete a letter
it depends on your model number.
Usually you can delete a letter by hitting the clear key.
Usually you can change predictive text to standard by pressing and holding the 1 key, the * key or the # key.
SOURCE: predictive text
Aswer is in the instructions, you can download off the internet.
http://support.t-mobile.com/knowbase/root/public/tm30114.pdf?&A2L.SERVICE=Manual&WT.srch=2&Result_Inq=answer&InqSource=TMO
1) Go to text entry screen (txt message screen)
2) Push the _ button at the very top middle of your phone.
3) The Message menu will open, go to Entry Setup and set your Primary Setup to TAP English.
This will fix your problem, I set my secondary Setup to Tap Extended.
I have just done this and have not given it a major examination, but I can send text messages now without any bother.
SOURCE: predictive text problems with my samsung u900
when on predictive text if you want to change a word just click the "0" button (one with the Cross sign) this will cycle though the different words for you
rate me please thanks
SOURCE: Unknown symbol on my Nokia E51
That symbol means that there are msgs waiting to be sent in the out box. You cant get rid of it as there are msgs in the out box. Either send them or remove them.
