Question about Sunbeam Food Mixers
I have a sunbeam hand mixer #2485. (an older model). I took out the only visible screw, but now, how do I take it apart without chewing up the plastic case by using a tool of any sort?
    Top Expert:
  • Sunbeam Master
  • 63,744 Answers
YOU DON'T THEY ARE NOT CONSUMER REPAIRABLE MADE TO THROW AWAY
Posted on Jan 08, 2019
SOURCE:
SOURCE: Sunbeam hand mixer. One beater not working
That spring does not turn the beaters. It is part of the beater release assembly. Probably one of the gears is worn.
Posted on Jun 05, 2008
SOURCE: Model #2366 mixer blade release problem
I found a site that says it has replacement stands for 19.95 plus shipping. You can check it out at http://www.bettervac.com/proddetail.asp?prod=SUN%2D84128&cat=293.
Good Luck
Dan
Posted on Nov 04, 2008
  • 118 Answers
SOURCE: kitchenaide mixer model KHM3WH-1
You can see the parts breakdown HERE. It looks like there are 3 screws on the bottom...
Posted on Nov 30, 2008
SOURCE: case disassembly Sunbeam 2485
Tossed it in the trash. Bought a new one.
Posted on Jan 20, 2010
SOURCE: We have a Sunbeam 2591
Gently pry the front cover off to expose the only two screws holding the mixer together.
Posted on Dec 10, 2010
How do I tighten the speed control dial on a vintage Sunbeam Mixmaster PowerPlus?
There is a cover plate over the screw that you need to tighten. This cover plate is held in place by two spring latches, 180 degrees apart. Use a small flat-tip screwdriver to depress first one latch, then the other. Don't use too much force - the latches are plastic and will break if treated roughly.
Jan 27, 2015 | Sunbeam Food Mixers
I have the Sunbeam portable mixer 2486. I was making Parker house rolls with the dough hooks. After blending the dough, the mixer just stopped. The motor will no longer be turned on or off. I want to...
Hi Janis.
You have likely burnt the motor. That is the most common fault when the mixer is used for a prolonged time on a compact dough.
The best thing to do is ringing Sunbeam at the number listed on the owners manual, and checking what conditions for repair are offered.
If you have misplaced the manual, then track the number using Sunbeam website: Sunbeam.
Regards.
Mar 02, 2010 | Sunbeam 2485 MixMaster Series Hand Mixer
Case disassembly Sunbeam 2485
Jan 19, 2010 | Sunbeam 2485 MixMaster Series Hand Mixer
12c 150 watt missing front dial
type in the manufacturer in the search bar and sometimes you can find the history leading to the current ,anufacturer and service centers. Good Luck
Sep 21, 2009 | Sunbeam 2485 MixMaster Series Hand Mixer
Sunbeam mixer
When you open it, there is are contact points and a piece that has to touch to change the speed. It may just be slightly bent or out of place. Some food may have gotten in there.
Nov 25, 2007 | Sunbeam 2485 MixMaster Series Hand Mixer
Sunbeam 2484 Beaters won't stay engaged.
In taking apart my same beater, I'm trying to figure out the alignment of the spring which provides the tension so that the beaters won't fall out. I'd assume that your spring has mis-aligned. You need to take it apart (3 Philips screws), and carefully pull the assembly apart. I'll bet your spring falls out like mine did. I'm trying to find a schematic from Sunbeam to see how the spring should align.
Nov 19, 2007 | Sunbeam 200 Watts 2484 Hand Mixer
Nov 12, 2006 | Sunbeam 2485 MixMaster Series Hand Mixer
Food Mixers Logo
101 people viewed this question
Top Sunbeam Food Mixers Experts
Vincent G
Vincent G
Bruce Showalter
Jerry Greenberg
Jerry Greenberg
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
