Question about Jabra Radio Communications
I have a Jabra talk 25 and want to now why I can't say answers or denied,before I bought it I ask if it does it thy said yes,it does everything I want to do but can't talk to it,can someone help
    Problem Solver:
  • 14 Answers
I have one too and was told that the Jabra is slowly fading out. I had to have mine replaced twice due to the same problem. go to where you bought this item and ask for a replacement for there is a warranty on these devices.
Posted on Jan 07, 2019
2 Suggested Answers
SOURCE:
ebonyhinojos
  • 10 Answers
SOURCE: I bought a new pc, when I tried to sync my pod It would not happen Talked to Itunes I could not answer sec question .Itunes said tough luck,and will not help
Here's an article to help you extract iPod music to your new computer. How to Extract Music from iPod
Posted on Dec 09, 2014
My jabra blue tooth asking for pass code , i tried with 0000 and 1111 and 1234 and 9999 but no use please help me
1. Put the headset in pairing mode
Make sure that the headset is on.
Press the answer/end button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to 'discover' the Jabra BT130
Follow your phone's instruction guide. This usually involves going to a 'setup,'
'connect' or 'Bluetooth' menu on your phone and selecting the option to 'discover'
or 'add' a Bluetooth device.
3. Your phone will find the Jabra BT130
Your phone then asks if you want to pair with it. Accept by pressing 'Yes' or 'OK' on
the phone and confirm with the passkey or PIN3 = 0000 (4 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
repeat steps 1 to 3.
Jun 21, 2011 | Jabra BT130 Wireless Headset
How to switch on jabra bt150 blutooth handset
First Fully charge the BT150. Turn BT150 on by pressing the "answer/end button". To put the BT150 into pairing mode press the answer/end and volume+ at the same time to activate pairing mode. Next Set your mobile phone to detect a Bluetooth device. Press yes or ok to pair phone with Jabra BT150. Put in pass key 0000 (four zeros) Then press yes or ok. Your phone will confirm when pairing is complete. Enjoy your earbud/headset.
Dec 26, 2010 | Jabra BT150 Wireless Headset
How to connet to cell phone?
Hi,this is a detailed description of how you pair your jabra headset to your phone;
Pairing Instructions:
1. Please ensure that the Headset is OFF, i.e the blue light is not flashing.
2. Press and hold the answer/end button until you see a solid blue light (approximately 8 seconds), then release.
3. Set your phone to “discover” the headset by following your phone's instruction guide. Typically, the steps involved going to a “setup”, “connect”, or “Bluetooth” menu on your phone and then selecting the option to “discover” a Bluetooth device.
4. When your phone finds the “Jabra BT125”, it asks if you want to pair with it. Confirm this by selecting “yes” or “ok”.
5. When your phone asks for a passkey, enter “0000” (4 zeros) from your keypad and then press “yes” or “ok”.
(Note: Pairing must be done every time the Headset establishes a link with a different mobile phone or other Bluetooth compatible device)
Thanks and take care
Apr 27, 2010 | Jabra BT125 Headset
I do not have my manual to sync my bt350 with my new phone how do I do this?
Before you use your Jabra BT350, you need to pair it with your mobile
phone.
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a
‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the
option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a
typical mobile phone in fig. 5)
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’
or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4
zeros).
or go here http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
hope this helps
Jan 30, 2010 | Jabra BT350 Bluetooth Headset Headset
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
• Make sure the headset is off .
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
PIN on my cellphone doesnt show after seeing Jabra 2050
FIX YA IS NOT PAYING US THE MONEY WE EARNED (MOST OF US)! AND A SUIT IS BEING FILED WITH THE DISTRICT ATTORNEYS OFFICE! I SUGGEST YOU GO TO ANOTHER SITE TO GET YOUR ANSWERS!
Feb 15, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Jabra BT8040 is not pairing with iPhone 3G
Make sure the headset is off. iPhone--Settings--Bluetooth---On---Press and hold the answer/end button for approx 5 secs until lite turns sold blue. It works
Nov 12, 2008 | Cell Phones
I couldn't get it to pair this morning
From the manual )link below),,,, 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press and hold the answer/end button until a solid blue light comes on. 2. Set your Bluetooth phone to ?discover? the Jabra BT350 Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* (See example from a typical mobile phone in fig. 5) 3. Your phone will find the Jabra BT350 Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Jul 28, 2007 | Jabra BT350 Bluetooth Headset Headset
Setting up pairing
# Fully charge your Jabra BT150 and switch on by pressing the answer/end button # Press the answer/end button and the volume up (+) button together, to put the Jabra BT150 in pairing mode # Set your mobile phone to ?discover a Bluetooth device? (see your phone user guide) # Press Yes or OK when asked if you want to pair the phone with the Jabra BT150 # Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK # Your phone will confi rm when pairing is complete
Jan 05, 2007 | Jabra BT150 Wireless Headset
Radio Communications Logo
46 people viewed this question
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
