Lights for regular and heavy duty remain on all the time. Knob turns but it will not change the light selector for the drying modes. When the knob is turned, drying times change but not the light associated with the drying mode option
SOURCE: ariston margherita wont drain and selector knob keeps turning
Plug off the wall first. The spin normally does not work when the outlet filter is clogged; be prepared for a flood of water. If the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
You can also drain water from the tub thru the rear hose in the wall. Keep bucket handy. The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
SOURCE: Selector knob on my Indesit Washing Machine WI 121 keeps turning
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
SOURCE: 2003 Saturn Ion Air Selector Knob broken
its a real easy one to fix i had the same problem you just need to take your radio out and then look down on the PLASTIC parts just need to put it back on track
good luck
