Question about Compaq Computers & Internet
I have a Compaq 7500 crt monitor I want to adjust its G2 how I do it
    Sergeant:
  • Compaq Expert
  • 360 Answers
SOURCE:
Benimur
  • 6966 Answers
SOURCE: dim compaq s510 crt colored monitor
Hi, If you are comfortable working with tools, down to component level and know how to work around EHV areas, then it is possible to increase the brightness of any monitor including the Compaq S510. Make sure that the unit is unplug, Open the back cover and locate the FBT. You have to run/power on/attach a running PC to the unit with the cover off. Extreme care must be exercised. If you are not sure, you're better off asking a qualified service professional to do the adjustment. There two plastic slotted adjustables, focus & screen. Adjusting the screen changes the screen voltage going to the CRT. This will make the display go very dark or overly too bright. Adjust to your preference (not necessarily technically correct) The focus may also be adjusted this way. You have to run the unit with the back cover open for a couple of minutes to stabilize the voltages and the heater/CRT/ Adjust after a couple of minutes if necessary. In other monitors, there is a trimpot (small variable resistor) the adjusts the sub-bright. Further improvement maybe achieved by adding a 100uF/250V capacitor across the supply of the 70+VDC of the 3 gun transistors. If you are sure how to go about this, it is best to consult or seek the services of a qualified TV technician who can either show where and how or do the job himself. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Posted on Jul 31, 2007
  • 3940 Answers
SOURCE: COMPAQ 7500 SET UP MANUAL
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=219439&prodTypeId=382087&objectID=c00507223
Posted on May 19, 2008
nileshsingh2
  • 246 Answers
SOURCE: I have an EIZO T962 CRT 21 inch monitor with bright screen
CHECK FOR DAMAGED RESISTORS ON BOARD NEAR HIGH VOLTAGE AND ALSO ON CRT SOCKET, ITS A COMPONENT PROBLEM, RECTIFY IT..CHANGE THE DAMAGED COMPONENT, ALSO CAPACITORS IF POSSIBLE..
Posted on Oct 16, 2009
pravinbhavsa
  • 348 Answers
SOURCE: Compaq CRT Monitor 7500 does not support hd
yes see if proper original drivers are installed or not .it can be solved by installing an AGP card into an AGP slot use 8X AGP card for better result .this happens because inbuilt display cad has no sufficient memory on the motherboard
Posted on Apr 06, 2010
urlftp
  • 300 Answers
SOURCE: compaq crt monitor 7500 est problem how can i open
open the menu and reset to default. please vote
Posted on Dec 02, 2010
Compaq 7500 crt screen not lighting up
The problem is the flyback transformer, or the crt filiment is open. Replacement of the monitor is recommended due to cost over run to repair.
Apr 01, 2012 | Compaq CV 7500 (Carbon, Silver) 17 in.CRT...
Compaq crt monitor 7500 est problem how can i open est
there is a menu button on the unit. you can get it please vote!
Dec 02, 2010 | HP Compaq MV 7500 17" CRT Monitor
My monitor hp compaq mv 7500 17 i am not able to turn it on or off
My guess is that the ON/OFF switch is broken.
It's time to responsibly recycle your old CRT monitor, and buy a new LCD monitor.
Oct 13, 2010 | HP Compaq MV 7500 17" CRT Monitor
Menu problems
if it is in warranty take it to the service center. if not replace the monitor is it an old heavy crt monitor or a new flat panel?
Apr 30, 2008 | Compaq CV 7500 17" CRT Monitor
Computers & Internet Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
