Is the output voltage very distorted. Won't even run my gas califont
SOURCE: No voltage output
It is possible that your voltage regulator is shot but before purchasing the volt regulator try flashing the fields first and make sure the brushes and rings are clean.
SOURCE: no output voltage at all
The generator needs to be 'flashed' to bring back the excitation for output. Is this something you can do? Let me know and I can help you...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: generator voltage too low
check engine speed by the sound...if normal then check AVR card...replace it...
if not normal rase it...
SOURCE: ust 3000 generator-only idles-no voltage output
chek brushes...if they seemed ok then replace AVR card
SOURCE: no output from my generator
Check the capacitor in the generator head. Will onpen or short cause loss of excitation voltage. Just checked my GENERAC ( no output) and sure enough the cap is shorted.
