SOURCE: Samsung SIM card issues!
you dont have to buy new sim...go to your nearest service senter. hardware failure.... sim sockets or sim ic... thats the problem...
SOURCE: hOW TO REMOVE SIMS CARD FROM SAMSUNG MAGNET CELL
ive had the same problem with the palm centro that i used to have, try removing the sim card with pair of tweezers.
SOURCE: how do you remove sim card from a samsung knack?
This phone is CDMA, so it does not have any sim card slot as it has inbuilt system which is directly operated by the service provider.
No other service provider is compatible with this phone.
Good luck
Testimonial: "Thanks, now I can just forget this problem."
SOURCE: how to remove sim card from samsung metro 3600....
hi
first switch off your cell phone. . then turn your mobile. kindly notice that there will be some direction symbol. gently press in hat direction. now your back side of your phone will be removed. that remove the battery . after removing the battery and notice that you will find the Sim card . in that you can remove your Sim card.. if you still having any problem in that kindly refer your manual of your phone...
thank you
SOURCE: unlock code for samsung a117 sim card my sim card
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website. This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked. Hope this helps.
