SOURCE: mda not charging
Either your battery is bad or your soldered contacts on the inside to the charger port are broken.
SOURCE: My z3 battery had die
u might need to get a new charger.......happened to my motorola phone.........or u should adjust the connection by moving it around a bit....
SOURCE: I try to charge my
please write your phone's model no. to get into the details..it may be a Software problem, if it is then a Firmware upgrade will solve the issue, but if it doesn't then it must be the Hardware problem and for that you must take it to the Customer care or to the repair shop.
P.S. try to use different CHARGER.
SOURCE: My phone will no longer
I think you have a dead battery try to change it and if it doesnt work it will be a charger connector problem
