Question about Dacor Ovens
My Dacor double wall oven panel shows L70 comm error and keep alarming, do you know just how to erase the alarming
6ya staff
SOURCE:
SenorSushi
SOURCE: dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Posted on Jun 15, 2008
reg501
Richard
  • 413 Answers
SOURCE: F1 error Dacor Oven
I'm sorry but I am not familiar with Dacor ovens, the research I performed indicated that the ERC (clock module) has failed. You could try the oven sensor probe if it is a temperature related issue.
I truly wish I could help you further with your dilemma but am unable to provide any further information except search the web. Good luck....
Regards;
reg501
Posted on Jul 02, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Posted on Aug 01, 2009
Anonymous
  • 3 Answers
SOURCE: Dacor double oven, lower oven works fine, upper
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Posted on Nov 27, 2009
Anonymous
  • 572 Answers
SOURCE: oven seems to work but the display panel dark.
Posted on Feb 11, 2010
My Dacor oven keeps beeping and flashing PRB. How do I stop the beeping?
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Jul 12, 2016 | Dacor Epicure 30" Double Wall Oven,...
How do I find the model number on a dacor double wall oven?
The MODEL Series you already said in your question: EO230SCH
Check and see if it is this model:
Good Luck!
Dec 06, 2010 | Dacor Epicure 30" Double Wall Oven,...
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Sep 19, 2009 | Dacor Epicure 30" Double Wall Oven,...
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Sep 22, 2008 | Dacor ECS230 Epicure Electric Double Oven
Control panel fan won't turn off
Is the oven still hot?? this is a Electronics cooling fan it will run even after the oven is turned off give it some time it should shut off let me know if not
Jan 26, 2008 | Dacor Epicure 30" Double Wall Oven,...
Ovens Logo
70 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Jaime Hernandez
Paul Bade
Are you a Dacor Oven Expert? Answer questions, earn points and help others
