SOURCE: Indesit Dishwasher
disconnect the drain hose and lower it into a bucket if no water comes out there is a blockage in the hose/pump.
SOURCE: no cold fridge
Open the freezer and listen for the evaporator fan. You may have to hold the door switch closed for it to come on. If you dont hear the fan running then you probably need a fan motor or or defrost bimetal depending on the make and model. If the fan is working, look at the back wall of the freezer. If you see a thick coat of frost, you probably have a problem with the defrost system. Also, check to make sure refrigerator light is shutting off when you close the door. A 40 watt bulb will curdle a gallon of milk quickly. Of course, you also want to rule out any possibility that the fridge door was left slightly open over night before you decide to toss it. Please reply back with what you find out. If you need further help, please post the brand and model number so I can give more detailed advise.
SOURCE: have a yellow amber light blinking
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
SOURCE: LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
SOURCE: Samsung PS50C91HDX Sound but no picture
It sounds like the main board or screen may have gone
Testimonial: "A quick one to respond with a good answer to the problem."
