Question about Sharp Televison & Video
Battery drains on my Sharp Aquos remote - Sharp Televison & Video
    Sergeant:
    Champion:
  • Sharp Expert
  • 279 Answers
Change Remote PCB capacitor and Transistor
Posted on Jan 07, 2019
SOURCE:
  • 15 Answers
SOURCE: WII Remote Problem-Since changing our TV to HD(Sharp Aquos
hi deborah, have you made sure the wii sensor bar position matches the wii sensor bar settings in the wii menu? have you placed the wii sensor in the same position as it was before? changing this may help, its not usually the batteries they tend to work well up until the wiimote switches off. hope this helps.
Posted on May 02, 2009
SOURCE: I need the 4 digit remote code for a Sharp Aquos
Try 0093 mate.....
Rgds,
Nik..
Posted on Jul 24, 2010
  • 4 Answers
SOURCE: tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Posted on Nov 27, 2010
  • 4 Answers
SOURCE: sharp aquos lcd, 6 months old. TV will not
try unplugging tv.
gopakumarg43
  • 76046 Answers
SOURCE: sharp Aquos 52" and all three remotes are now
Hello
Remote sensor is a three terminal component, comes just behind the remote window at the front panel of the TV. It can be desodered out from its circuit board and can be replaced. Just open your TV and locate the remote sensor board, unscrew it out, desolder out the remote sensor, and go for a new one. It has a number printed on its body and should be noted. There is no other things to be concentrated other than its position, which you can note while desoldering it. OK
Posted on Jan 25, 2011
My Sharp tv remote will not turn on / off tv. It will turn on by the main power switch on tv but not by remote.
From page 8 of the manual:
The POWER indicator on the AQUOS television should light GREEN indicating you have power to the AQUOS television.
If the POWER indicator on the AQUOS television still does not light up, press TV POWER on the remote control to turn the power on.
IMPORTANT:
IF THE UNIT DOES NOT POWER ON - UNPLUG THE AQUOS TELEVISION FROM THE OUTLET AND REPEAT THE INSTALLATION STEPS.
IF YOU STILL ENCOUNTER NO POWER, PLEASE CONTACT US AT 1-800-BE-SHARP
http://www.nemsworld.com/theater/LC46_52D62U_Manual.pdf
Dec 04, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My Sharp aquos won't resond to remote
Replaced Battery of remote.keep your mobile camera ON and press any from remote.If you get flash light in camera that means your remote is ok. Checked & Replaced LED TV sensor pcb.
Jul 26, 2014 | Sharp LC-60LE820UN AQUOS 60 In. 1080p LED...
Lost the remote for my sharp tv. And the control panel is locked. Who do I unlock the control panel with out the remote?
If the problem you are having is that the television's operation lock out for the buttons on the tv has been enabled then the only way to undo that is with the Sharp remote control. The only work around I can think of is to perform an INIT, which is a factory reset. I do not know is Sharp customer service will still walk you through that over the phone because it is a detailed and dangerous (in that it can wipe the memory of your television if done improperly) process. I do not know what type of Sharp you have i.e. aquos or non aquos. 800-BESHARP is the number for non aquos support and 877-332-7867 is the number for aquos support (open 24 hours for aquos support last I checked)---32 inch and over aquos that is.
Aug 20, 2011 | Televison & Video
I need a dish network code for a 52" Sharp Aquos.
Hi deidrapleasmy name is Mike Houston of DISH Network and I was going over your post and thecodes for your 52" Sharp Aquos are 628, 739, 521, 629, 741, 679, 112, 605, 625,111, 608, 740, 526, 585, 607, 652, 654, 655, 658, 669, 670 and 674. I will sendthe link to help with the setup for the remote to TV. http://www.dishnetwork.com/SupportSection/remote-control
Feb 14, 2011 | DISH Network IR Remote Control
Sharp Aquos tv remote Programming code for Pace(Mediacom)cablebox
Check the cable box for the manufacturers name and see if that isn't listed in your owners manual.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to Operate a sharp TV without a remote control
HOW DO I GET A REPLACEMENT REMOTE CONTROL FOR SHARP AQUOS LC37GA4X
Dec 10, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Code for sky+ remote cotrol
If you mean you want to program the remote to control your sharp tv, here is the list of sharp codes:
0093, 121, 121, 064, 065, 081, 322, 122, 185
Mar 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
37 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
