SOURCE: Sansui TV code for a rm-ez4 remote
Ask Manualfox.com - it is a personal Document Search Service for electronic user, service manuals and drivers. They help you to save time and money by finding your needed product information.
SOURCE: code for universal remote rm-810
There is an easy way to setup this remote controllerl(RC). It called "Automatic Code Searching" which means that you don't have to even find the code. The controller will searching it for you. Just do the following steppes.
1. Turn on the "Device" to be remotely controlled, e.g. TV, VCR.
2. Point the RC right to the "Device" .
3. Press a device button on the RC represent the "Device", e.g. TV, VCR, DVD etc. You can see the indicator lid flash once.
4. Press the SET and than the POWER button on the RC. hold both buttons for 2 seconds or more, you will see the red lid on. then release both buttons simutenously. after that the indicator lid will be flashing, means the searching started.
5. Keep pointing the RC to the "Device" until it is shut down by the RC, Press any button in 1.5 second to finish the setting.
You can try the RC now. It should work. My one is working.
SOURCE: i digital universal remote RM-810 - need code for
Try 184 for the NEC TV.
Please rate this solution. Thanks.
SOURCE: i need the 3-digit code for my sharp tv code
Here is a link to an extensive list for your 3 digit code to use with Chunghop
preprogrammed remote controls it includes scanned copies of 6 different
versions, plus a cross-reference chart. I hope this helps, if it does please let me know by giving me a yes helpful rating~
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=chunghop&dv=universalremote&md=chunghop3digitcodescollection&kw=&st=&ar=&dt=&so=&pg=1&file=others/chunghop/chunghop-3digit.zip
