Look at the back of your fridge by temoving lower vent / avross panel on outdide. Find the 12v power wires that are likely coming up from floor of compartmentn. They should go to a small terminal block. Make sure they are tight here, on both sides of the block.
Look closely in this area for a fuse holder, probably valued at 25 amps. Check this fuse, replace as necessary. If blown, can be caused by dc heater failing or converter may have surged while running on the shoreline.
Find the AC outlet where fridge is plugged into. See if it has a reset button on it, otherwise check bath and kitxhen outlets for an ourlet that resets the ground fault / earth leakage function. If this is tripped, may have been a surge when operaring on shoreline or generarator or a wiring problem could be present.
You may also have a bad mode switch, especially if frisge is gerting both 12vdc and ac power to it. Its not unusual for propane to continue to be able to operate since that is the preferred mode for most rv / caravan refrigerators.
Service Manual:
https://www.dometic.com/assets/86/36/54-223-maw41a_rev_48636.pdf?att=true
SOURCE: Our dometic RM 2350caravan fridge
Hi, you have a freon leak in your system, with the caravan refrigerators they use amonia as a cooling media. You need to either have a service person the knows this system or purchase a new one. thanks.
