Microwave Ovens Logo
Mala Narasimhan Posted on Jan 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can we bake biscuits in a microwave with grill facility?
Vernon Taylor
Level 3:
  • In Master 7,446 Answers
  • Posted on Jan 06, 2019
 Vernon Taylor
In Master
Level 3:
Answers
7446
Questions
0
Helped
1956066
Points
26207
You can try it but I doubt the results would be good. A microwave oven can cook many foods quite satisfactorily but left many dishes looking anaemic and unappetising which led to the introduction of in-microwave gadgets such as browning dishes which would react with the microwave energy and become hot enough to sear meat. Adding a grill facility to a microwave means those gadgets are no longer needed and food can appear more appetising by being seared or browned on the top surface while the rest of the food is cooked by the microwave. When using the grill facility it is necessary to raise the food on a microwave approved trivet - a small lightweight wire construction so it doesn't interfere with the microwave energy and is hardly suitable for balancing a baking tray on.
2 Related Answers
ukvacfan
Ryan S
  • 328 Answers
  • Posted on Jul 25, 2009
SOURCE: I have microwave Oven with grill only and no
Sorry this isn't a forum for helping you out with receipes.
A grill means you can use it put cheese on bread (toast eventually) or to give COOKED meat or fish a brownish effect when the grill function has been activated.
Anonymous
  • Posted on Jun 15, 2011
SOURCE: How do I get the
Spray the inside with Dow Scrubbing Bubbles Bathroom cleaner, let foam, wipe clean, and rinse. Then if the odor persists, mix one part vinegar, two parts water in a bowl, set inside the Microwave and turn on for five minutes.
Can the prestige microwave ds20 be used for grilling and baking?
baking only if it is a combination microwave / convectional oven and no for grilling
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
1helpful
How to use the Tesco mtg06 microwave grill?do not have instruction manual
The oven may be used purely for microwaving or simply as a grill for cooking such things as toast. The radiant or quartz grill may be used in a variety of ways. You can use microwaves that have grill functions to roast foods, for baking purposes or for grilling food such as bacon or sausages on the racks. Some models also allow you to use both the oven and grill together, and you can produce fantastically presented meals by using the grill to brown off your dish after cooking. The grill will often have low, medium and high settings for you to choose from, letting you control how brown your food is. By using a microwave with a grill, you can prepare great meals or snacks in a fraction of the time that it would take if you used a conventional oven and grill. Microwaves are particularly convenient, as you don't have to keep checking on the food or stand over it as it cooks.
How do I get the burned smell from my Whirlpool microwave. All I did was overheat a biscuit. We've tried vinegar, baking soda, Fabreeze and lots of other stuff. Can you please help us? Thank you. ST
1helpful
I hv got a ifb microwave oven 23sci with grill , i have tried baking cakes many time and every time it gets burnt. The sides get baked and the central zone is unbaked. MY method is , I take a glass utensil...
You should be using convection mode first of all. It's not clear from your post if you are. Also looks like you're oven is baking at higher temperature than it says. Try 170 degrees for 13-14 mins instead.
Top In Microwave Ovens Experts
vince
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
