Question about Razor Cycling
My razor mx650 will turn on with power connected to the batteries bout it will not drive and I had just washed it and all the other times that I have washed it it worked fine. So what is the problem.
How to replace mx650 Freewheel Clutch
You can buy a tool online that grabs the free to turn it off if the wheel center hub. Looks like a socket with 4 teeth.
Jun 20, 2014 | Razor MX650 Electric DirtBike
Low power
Yes, your batteries need replacement, that will solve the problem.
Mar 19, 2013 | Razor MX650 Electric DirtBike
Rear wheels won't move chain just spins
I posted a solution to this previously, please check it out.
Aug 27, 2012 | Razor MX650 Electric DirtBike
Razor MX650
It is the rear freewheel assembly causing the problem. if is fixable, but you have to be good with tools, the bicycle shop and the electric bike shop both said they couldn't fix it, but is is doable. 1. you need a special bmx tool that fits that back wheel, your local bike shop should have it in stock. 2. you need to remove the freewheel sprocket and disgard it along with the the bearings (make sure to unscrew the razor chain sprocket from the freewheel assembly and secure it for reuse). 3. either purchase a new freewheel sprocket for bmx wheel or remove one from a old bike (again you will a special tool for that). 4. screw the razor chair sprocket onto the new BMX sprocket (it goes on with the same 4 original screws, right over the sprockets. 5. Screw the freewheel back onto the rim now. tada its fixed.
Jun 03, 2012 | Razor MX650 Electric DirtBike
How do i adjust the chain on the mx650
The chain tensioner is on the right side of the bike a few inches or so in front of the tire on the rear swing arm all you do is adjust it up to tighten and down to loosen it.
May 30, 2011 | Razor MX650 Electric DirtBike
7526 twist cord and razor speeds up
Based on the limited info provided, it appears you have a rechargeable razor that you plug in to recharge.
I had this occur with an older shaver I had years ago. The suspected issue is tha the battery isn't fully charged and the razor is running on battery power while the cord is plugged into it and the power outlet.
However, the cord is making a loose connection at the razor or has a broken conductor in the cord. So and what is happening is that you arfe getting an intermittent power connection that allows the power to run the razor, which would be why it seems to "speed up" as any rechargeable product always run faster/better when connected directly to an electric power source.
You can look at the plug on the razor to see if the pins/connector is loose, and also carefully check the cord to see if shows signs of having been sharply kinked or bent at the razor plug end or at the power plug end or along it somewhere.
It could be as simple as replacing the power cord. Or you may have to take the razor apart to repair the charging socket at the razor to resolve this issue.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Health & Beauty
My TOSHIBA laptop won't turn on
flashing three times means something physically wrong with ur laptop. could be fault with ur power supply, Hard drive or ram.
- with the battery, plug in ur power supply and check if ur LED is glowing and the laptop is charging well.
if the problem persists,
- reset the RAM and the Hard drive, [ for this take out the ram and Hard drive and put them back again].
if still the problem persists, take it to repair. ---------------------------------------------------------------------------------------------- u dont have to worry bout the backup in ur laptop. a simple solution would be to get a 2.5 inch hard drive enclosure, install ur harddrive into that, connect it to a different computer and back it up!, but be sure what type of Harddrive u have , is it a IDE harddrive or a SATA harddrive.
cheers suraj
Oct 10, 2008 | Computers & Internet
Cycling Logo
83 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
