SOURCE: wifi problem
HI,
Open comm manager , and tap on the Wifi icon, to enable the wireless connection
Then click on settings and tap on wirelss lan
Check under the main tab
If you are getting the configuration setting and if they are correct.
If not tap on the change network tab and then see.
Note : WIFI lan would only work if you are near a hotspot or a wireless router. It is not dependent upon your cell phone provider
Thanks
Proton
SOURCE: Wireless connection is strong but I cannot connect to internet
You are connecting to a secured wireless network without entering the correct passphrase.
SOURCE: Acer D150 Netbook - I get a good WIFI signal but
go to my network place then go to local area connection logo and right click on it then go to propeties after that u will see a window crew down to TCP/IP once u are thr click on properties to ur left then fill in the code after than click okay and make local area connection your default connection. thats it u are done
SOURCE: Wireless computers lose signal
try reset wireless settings
or reset to defaults and use a wpa2 Encript security.
Testimonial: "That worked.Thanks a lot"
SOURCE: WL-520GC... wifi signal very good; but no internet connection...
login to the router page and you need to configure your router settings as per your internet service provider then save the settings and reboot your router and check it
