SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
SOURCE: How do I change my whirlpool oven back to Farenheit instead of celcius...
its in your manual, did not give model number so i looked up anyone. if this does not work you can enter your model number here for a copy of user manual
http://shared.whirlpoolcorp.com/product_literature/search.jsp
To Change: Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit.
SOURCE: replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
SOURCE: Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
SOURCE: I have a remote control unit Model : AR-RY7
Jane,if you are still interested: Go to www.fujitsugeneral.com, click consumer, click service and parts, click manuals. Enter the model number of your indoor unit = small numbers on right hand side (e.g.,asu12rmlq and put plenty of paper in your printer. I had 19 sheets. Lots of luck. Bob
