Question about Measuring Tools & Sensors
Fluke 87 reads Lead and beeps on and off ,changed battery and still the same
    New Friend:
  • 20 Answers
If you select current measuring (A or mA) and have the test lead connected to V then you get this alarm. Same thing if you select Voltage measuring and the lead is connected to a current terminal.
Check the connections and the selector setting.
Posted on Feb 10, 2019
2 Suggested Answers
SOURCE:
  • 717 Answers
SOURCE: why always display ''lead '' fluke 88v
Fluke 88 V displays "LEADS" warning if test leads are in A or mA/uA terminals but switch position does not corespond with those terminals.
Remove all leads and if you still get "LEADS" warning try cleaning all terminals with air. Sometimes dirt gets in A terminals and unit thinks that leads are connected.
Use compressed air or airduster to blow dust from all terminals and hopefully that will fix the problem.
Posted on Jan 08, 2012
Fluke 87 multimeter reads/blinks "lead"
clean terminals with cotton bud and ISO and then blow with air
dirty terminals may trigger 'leads' error
Nov 27, 2013 | Fluke 87V True RMS Multimeter
Fluke
Try using compressed air to clean terminal block plugs (specially mA plug) - something is stuck there and unit thinks that you have your leads connected to mA and setting and will beep if you turn knob to any other function.
Jul 19, 2013 | Measuring Tools & Sensors
Fluke 87
Terminal is dirty inside and unit thinks that leads are connected to mA terminals and knob is at Volts,
Use compressed air to clean terminals and if that does not help use cotton bud with little alcohol on it to clean terminals inside. It will fix the problem.
Fluke
Try cleaning terminals ( dirt inside triggers leads message).
use cottons bud and some Iso.
May 10, 2013 | Fluke 87V True RMS Multimeter
How do you change battery on fluke 1550b
You will have to open the meter and remove old battery and replace it. If you are not sure how to do that find someone that is technicly minded because it's not that hard. Battery is
12 V lead-acid rechargeable battery.
Yuasa NP2.8-12
Dec 26, 2012 | Fluke 1550C Insulation Tester,battery,50...
Fluke 87-5 affiche F8
F8 Error - invalid model -you will have to return to Fluke for service
May 16, 2012 | Fluke Networks Fluke 87-5 Digital...
Fluke 87-5 affiche ERREUR F8
No beep on continuity mod
Needs new buzzer disc, or maybe buzzer disc fell out of its place and just repositioning it fixes the problem - this is the likely cause of your problem.Contact local Fluke authorised service centre or Fluke directly if you are in US and ask them for Audio Transducer (Part Number: 2041050). it should not be more than couple of dollars.
Mar 18, 2012 | Fluke Networks Fluke 179 Electricians...
Measuring Tools & Sensors Logo
198 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
