e
eduhkim Posted on Jan 04, 2019
Error 30.01.08 on hp laserjet m5035 mfp printer
[email protected]
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 30, 2019
Tonerdude746@gmail.com
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
795
Points
5 Related Answers
Jalal Sordo
  • 1800 Answers
  • Posted on Jan 22, 2009
SOURCE: my printer name is HP
fixed the problem by removing the scanner cover and sprayed compress air on the scanner light bulb and cleaned it out.Put back together
Anonymous
  • 14 Answers
  • Posted on Feb 23, 2009
SOURCE: 60.40 Error Message on HP Laserjet 5025 MFP printer
Hi
Welcome to Fixya
Have alook at the webpage by following this link:
http://servicelineat.ro/hplaserjetm5025.html
Scroll down the page for error listing. Unfortunately error 60.40 is not listed. It may help to ring HP service centre for a full error code list.
Hope this helps. Please don't forget to Rate this solution.
Thank you.
Walid M Sayed
  • 313 Answers
  • Posted on May 07, 2010
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
[email protected]
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Mohammed Fiyaz VA
  • 143 Answers
  • Posted on Mar 20, 2011
SOURCE: scan note working (Hp Laserjet
Lets check whether windows detects your scanner
Right click My Computer > Manage > Device Manager
Under Device Manager check Imaging Devices
If there Double click Imaging Devices and check the device under that. If you find your scanner there .Then the scanner is installed properly
Now Lets try a test scan
If Windows Xp do this .
Click start > Run > Type wiaacmgr.exe press enter key
Now take a test scan
If your windows is vista / win 7 then
click start > All programs > accessories > Run
on Run window > Type wiaacmgr.exe press enter key
Hope this would work
Please rate me if you are satisfied with my answer
Anonymous
  • 304 Answers
  • Posted on Jun 28, 2011
SOURCE: How do i Print individual
Usage page
Shows a page count for each size of
paper printed, the number of one-sided
(simplexed) or two-sided (duplexed)
pages, and the average percentage of
coverage.
1. From the Home screen, touch Administration.
2. Touch Information.
3. Touch Configuration/Status Pages.
4. Touch Usage Page.
5. Touch Print
Hp laserjet m5035 mfp error 49 ff04
I think you are since the dc controller only controls paper movement and nothing else. A 49 error is a firmware error and has many causes from applications, network and just defective formatter. If the errors occurs with the printer not connected to anything, then the formatter would be the logical issue if the firmware has been updated. Keep in mind having a jet direct card in the slot can cause the error, so the only true way to test is with everything removed with the exception of firmware, memory and power. Also keep in mind that if the 4250/4350 series power is derived from the lvps and not the dc controller. Also with this model the embedded jet direct card is known to occasionally have issues. When you upgrade the firmware for the formatter it also upgrades the firmware on the embedded nic card. Again the only true way to test would be to disable the embedded nic card on powerup.
Read more... HP Support document HP Support Center and HP Printer Support
13.4200 jam in side open the left door
Open the door and you may need a flashlight to search for the paper. Check your feed rollers also. If they are not feeding the paper you will get this error
Initializing scanner
Update the firmware
Restored factory defaults
Initialization of the hard disk.
If it still doesn't work try to clean the scanner head under the glass. Clean the lens with some alcohol but be careful not to scratch the lens.
HP Color Laserjet M5035 get`s error 30.01.34
First, this model is not color laserjet, only black.
HP LaserJet M5035 MFP
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. If the message persists, replace the scanner control board or replace the formatter.
How do i Print individual usage report on Hp laserjet M5035 mfp multifunctional Printer.
Usage page
coverage.
5. Touch Print
Hp printer lj m5035 in 69.30 error
According to Hp official site,
A temporary printing error occurred.Turn the device off, and then turn the device on.
If this message persists, contact an HP-authorized service or support provider.
Goodluck
How do I create a quick access folder on the hp laserjet m5035
hi
it there in user manual
just refer you manual u will gind you solution
1helpful
My printer name is HP M5035 MFP LASERJET serial number cncxbo4735.it can't scan or photo copy error code 30.1.19
k24674
Grand Canyon Tech
Grand Canyon Tech
