Computers & Internet Logo
D
Denis Posted on Jan 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can my router B618s output to 108.11/ac be attenuated?
Robert Miller II
Level 2:
Habit-Forming:
  • Expert 98 Answers
  • Posted on Jan 08, 2019
Robert Miller II
Expert
Level 2:
Habit-Forming:
Answers
98
Questions
0
Helped
39311
Points
480
There are no user accessible antennas to remove or modify, so unfortunately the answer is, no. Short of wrapping the thing in aluminum foil.
9helpful
4answers
Need a replacement for linksys wireless-g wrtp54g power cord. Bought a 300mA adjustable one, but it didnt work; do I need the 600mA?
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
Need manual
A DI like this is so simple one doesn't need a manual. If you get buzzing or hum, try opposite setting of the Grd Lift switch. This switch breaks the ground connection of the XLR output connector to the case/shield. The attenuation switch allows you to vary the output from this for devices that generate different levels. Set the attenuator to 0 for low level devices and to the middle setting for mid level and use the -40 Db for high output devices. The two 1/4 inch jacks are in parallel so you can for instance run an instrument into one and back out to your amp and the XLR then goes to mixer for the house PA. Passive guitars you would usually use the 0 Db setting and keyboards often the mid setting or the-40 Db. One caution as I use these boxes... it is easy to leave the slide switches "between" settings and you will get no output.
I have a Netgear wireless router WGR614 v5 with the AC adapter of 120V-60Hz-16W. I've moved to Europe where the electricity is 220V. Can I use an AC adapter of 220V for this wireless router? Thanks a lot...
Yes, make sure you have a new power supply with the right voltage output, enough current (if the new power supply is rated for more current output, it will be OK), and the right plug with the right polarity.
Check your power supply, some will actually work with a wide range of voltage, some actually go from 100-250VAC. 50Hz-60Hz
Attenuated output
Since you are able to view the output i'm assuming you are using an oscilloscope and only the positive or negative half of the sine wave is displayed. The output stage will be using a complimentry pair of output transistors, one amplifies the positve half cycle the other the negative. These are driven by a driver stage (phase splitter). One side is not amplifying. First measure the pos' and neg' LT supply rails. If ok check
ouput transistors with analog Ohm meter for base / emitter / collector continuity. If the amp uses an output IC and LT supplies are ok then use scope to view input signal, if input ok but output bad then IC is suspect. Since both channels are affected your problem is most likely a missing LT supply rail.
I just hooked up my alpine 9886 .I have volume on the subs but none on the other 4
You have turned off your "POWER IC" option. This truns off the internal amplifier and only attenuates the output the the RCA terminals. That's why only your sub output works.
1helpful
2answers
Reduce output
make sure your tape monitor switch is not on.
Grand Canyon Tech
Grand Canyon Tech
