Sometimes it is needed to defrost the inner parts of the fridge to unblock the ice that forms inside keeping the ventilator from working the proper way or even not turning at all. Keep the goods in a cooler while you turn it off and open the door to help defrost faster, you can also use an extra fan to help and make it faster.
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
SOURCE: Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
SOURCE: Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
SOURCE: My ice maker on my Maytag MFI2568AEB stopped.
Hi, You can use a hair dryer to thaw the inlet tube out. Some mofeld will aloow you to remove the inlet tube from behind the refrigerator. If yours can be removed, this would be the easiest way.
If the tube plugs up again, you should replace the inlet valve. Thhey sometimes will drip a little causing the inlet tube to freeze.
I hope this helps you. Please let me know if I can assist you further.
Vic
SOURCE: GE GSS201EMD CC
Your problem is the Defrost Heater Assy. I know because i own the same model refrigerator. The first time I had this problem I looked at the same things you did. I then called a repairman who charged me about $140.00. I watched what he did and asked questions, that's how I knew what the part was called. The repair lasted about a year and YES it happeneed again. I ordered the part myself this time and did the repair myself. And now after six months it has happened again. I will never buy another GE refrigerator. In fact I have heard that there was a recall on this model (lawsuit), but the window has passed and we are stuck with this crappy refrigerator. The repair is simple and you can get the instructions online. The part costs about $30.00 which you can also order online--Isn't the internet great. Hope this info helps.
