Have too dual 4ohm voice coil sub have each wired to a final 2ohm each will I get the 1000 watts to each speaker¡¿
SOURCE: wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
SOURCE: sony xm-D9001GTR mono and kicker 4ohm dual voice coil
its a good amp but dont power ur amp at full put it at about half power
SOURCE: Subwoofer Dual voicecoil wiring
1 ohm will draw too much current.those are designed for a 2 channel 2 ohm drive for each sub.running 4 ohms will be easier on the amplifier and since impedance is not constant it may run 3 ohms at some frequencies anyway. another solution if your power amp is bridgeable....put the coils in series on each woofer making 4 ohms.then parallel the two 4 ohms to make 2 ohms and run the amp in bridge mode at 2 ohms.since bass is omnidirectional,you can do it
SOURCE: Wiring options
Yor best bet is to wire each one positive to neg to get 8ohms then pos-pos and neg-neg to get 2.66 ohms. Otherwise series parallel. If you wire them all pos-pos and neg-neg you will be running .66ohms and will most certainly fry your amp or it will overheat and shut down all the time
Testimonial: "I appreciate the quick reply, it answered my question fully. Thanks Again, -Chino"
Hello chino2g,
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
Hope this helps.
