Pentax CBT 1000
Could be a bad bearing...but keep in mind, electric motors are not all created equally. If the shaft is bent even slightly, it will still work fine but will be noisier. Some bearings are looser than others, making it noisier. Even the way the pump is mounted can cause vibration therefore making it noisier. There are many things to take into consideration.
SOURCE: Achiever 260 AF for pentax
Check the voltage trigger of the flash, if you're under 7vdc. Then you are good to go.
[email protected]
SOURCE: Pentax p30 camera
Hi - You can download the manual by clicking the link underlined in blue below:
Pentax P30
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: USER MANUAL FOR PENTAX CAMERA
Could someone please tell me what battery is used for the Pentax ESPIO 738S shoot and point camera. I picked it up second hand and it has no manual or accessories. As far as i can tell it needs a lithium battery but i don't know which one or what size. Also if you know of anywhere i can get an electronic copy of the user manual that would be handy aswell.
Thanks for helping with my dilemma.
Jennifer
SOURCE: Pentax e10 shuts off The pentax optio e10
You probably set the auto power-off for energy saving
SOURCE: Pentax ES2; do bayonet lens fit digital Pentax SLR?
Any Pentax K-mount lens will fit any Pentax DSLR. The DSLR will fire the shutter. There is a menu setting (RTFM) which allows the use of older lenses, but you will lose some of the automation (again RTFM). Remember to allow that the effective focal length when using a "film" lens on a DSLR body goes up by 50%.
A standard 50mm lens becomes a 75mm equivalent, but stays a large aperture.
