Televison & Video Logo
E
Elissa Elliott Posted on Jan 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rca model rtr4060bus . The screen will only show a picture in the top left screen. How do I fix this
Jeff McCrea
Level 2:
Novelist:
  • Expert 144 Answers
  • Posted on Jan 04, 2019
Jeff McCrea
Expert
Level 2:
Novelist:
Answers
144
Questions
0
Helped
40690
Points
434
I'm not sure about your particular TV but go to your menu and see if there's a setting for picture in picture or "PnP". If this is the case and you had a DVD player plugged in and operating, you would probably be seeing that picture too. Good luck.
Tv screen has gone black but still have sound when you shut the tv off and turn it back on the screen comes up but it flashes and goes black again
Hi Bob, The link below is a YouTube video showing how to fix a RCA television(DIFFERENT MODEL) NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
RCA 46LA45RQ tv repair No picture no power troubleshooting
I have a 20F42OT - is there someway to change the screen so the entire picture shows? for example, if there are sports scores on the bottom of the screen, you can see only top half. Screen should be...
does the remote have a aspect button? or maybe it is in the menu? If not let me know and I'll look it up. I have worked on some of these but dont remember them being wide screen
1helpful
Screen showing lots of colors caving in on top
You have no power to your convergence circuit. Depending on what model RCA you have will determine which parts are bad. Will cost about $200-$300 for a repair shop to repair.
1helpful
Sanyo 42" 1080p, picture doesn't fit on screen
this is normal and this feature is for wide screen programs! normal shows and games will lose part of the top of the screen sides and bottem because it zooms in on whats in the middle of screen! hope this helps
1helpful
RCA D52W17 Picture is cut off at the top of screen
is it a black area on the screen? or just cant see the heads anymore? either way its proabaly a setting on the remote such as zoom or ratio
RCA 40 in
Are you using just one box on this set. I suspect a bad set-top box...accordianman
Thin Red Lines on Top of Screen
Sorry, that is common for generic replacement xformers for
your make / model . There are some adjustments to minimize
the effect in servicer menu...............you can try turning down the
screen control a bit....................T.
Rca p52771at - dark picture
Sounds like a bad screen asy,part number 204809,must use the generic,or you could have weak tubes,if so you may just need to turn up the screen drives,this part is located in the right top of the set with the back removed,if no cracks are present adj. the three marked screen's,turn the color all the way down in your menu and adj. for a black and white picture.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
