SOURCE: Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
SOURCE: Vizio VA26L - Tuner problem. After approx. 6
Take the set and reprogram it where one of the other sets are ok. Digital signal is not so forgiving as analog, also place one of the sets that is receiving that station in place of the not receiving one. It's possible that the signal level at the bad spot is on the border line and that model can't hold on to it. You may also check visio's web site for any software up grade to your model that you may have to down load.
SOURCE: starview channels missing
if your on telewest change your provider to c & w and enter the relevent codes do an autoscan and you should get channels back
SOURCE: Unable to rescan channels AWA STB 262 set top
These STB262 box remotes won't work if they are not hooked up with the 720dpi option (Use HDMI Cable) -
Cheers - compac
